loulou8326 (4th April, 2020)
This is guide i used. Seems like it is hardware problem in my case.thanks
Sent from my GT-I9100
Hello!
I have a dump 11.11.3PL. As someone interested in inviting the PW.
I have small problem with RL cable. After reprogramming when I plug it into the car or test it on the table with external power 12V sometimes led goes green sometimes not at all. Looks like the power doesn't go true. When led light green cable works fine, but when led doesn't light up then I've got message cable not plugged into the car. Sometimes I have to couple times plug in and unplug the cable into the car to powered it.
I don't know where is the problem, I've checked all connection and I didn't find anything. Do you know where is the problem?
There is 5V at the output of the 7805. I think the problem was with connection under the GAL. I tried to fix the cable making wire connection instant programming and solder back the GAL. I fixed couple times few RL cables and everything worked perfect, but this time when I powered up the cable sometimes power goes true and led light lights up and sometimes doesn't. When I soldered back the GAL there is no more problems with the power.
[QUOTE=Meat-Head;1657944]Do i have enough posts?
Posts with a little bit of sense - not your bullshitting
Just joking :P
VAG
My VCDS original installers.
If you f*ck up your cable don't blame me
http://sdrv.ms/RN4Ooq
By the way 11.11.4 with a new FLASH is out... and no, I am not sharing my EEPROM dump
Regards.
Guys please don't fight.
As you all know if you like to extract the dump which can works with original installers you need to extract from an old kind of tool ( with BM ). This means that the serial to be alocated to a interface with FTDI232BM.
This kind of interfaces are very hard to find.
Now if you extract the dump from a new kind of tools with FTDI 232RQ ( which has it's own ID ), the serial alocated to this kind of tool will ask you always about the FTDI ID ( I mean the VCDS softwears will do this ). The FTDI232RQ ID it is unique.
In this case if you extract the dump from tjis kind of tools with FTDI232RQ you need to modify the VCDS softwear ( the exe file ) to pass the ID.
In this case you cannot use the original softwear from ross-tech.com becasue you need a loader or a moded softwear.
So from what I know Mr. Spychu14 can extract the dump from any VCDS tool and maybe he can make a loader to works with VCDS in Polish.
by the way interfaces with FTDI232BM will be very hard to find because are very old ( relesed 607 or 704 was the last one ) and in the mean time this once was replaced with the once with FTDI232RQ.
And also if you have a dump extracted from a new genuine tool and you make a loader or you mode the VCDS softwear just to pass the FTDI ID's and this softwear get to internet in few seconds the dump will be considerated CLONE and it wiil be blacklisted.
Maybe that's why the dumps cannot be shared, expecially the once from this new once. BUT you can make the softwear to not "get out" to the internet.
Sorry sometime I'm talking to much
Good luck
To me brought in repair a cable. This cable had the same breakage. The cable was sometimes launched if to include to switch on, switch off several times. The static electricity damaged the output cascade of the oscillator in a chip atmega. Fuse-bits were correct. It was necessary to change this chip. But I wanted to read eeprom atmega. I assembled the external oscillator with frequency 7.xx; MHz. I used chip CD4060. I gave a signal on input XTAL_IN. And the cable works already long.
The program (software) remains original when using a loader. Some byte changes. And the result of check ChipID becomes the true. Therefore dumps from new cables work also as well as dumps from old cables.
