Page 208 of 854 FirstFirst ... 108158198203204205206207208209210211212213218258308708 ... LastLast
Results 3,106 to 3,120 of 12803
  1. #3106
    Jul 2012
    Hello
    Well, my pulse is not what it was and almost break the cable, fortunately works well with the version I have.
    but I like it, try to do these things and buy another with a different version if not fool me with Atmega and BL, and I think firmware 1.91
    When you have it in my hands, I will try to do it again
    greetings and thank you all for your help
  2. #3107
    borysgo2's Avatar
    GAL remove solution.
    One of members GF forum posted how to remove GAL from pcb with RL chip, today i did cable with BL usb converter, there is only one small diffrence. Hope it will be helpfull.
  3. #3108
    Junior Member perotok's Avatar
    Croatia
    Quote Originally Posted by borysgo2 View Post
    for BL/BM cables is not necessary to remove the GAL (only for RL cables)
  4. #3109
    Oct 2008
    On Earth
    Is there anyone who has the new firmwear ( flash ) 1.92?
    If yes please share it here.
    Good luck
  5. #3110
    World
  6. #3111
    RF
    Quote Originally Posted by mattydr67 View Post
    ... Is there anyone who has the new firmwear ( flash ) 1.92?
    If yes please share it here....
    It is a flash from cables of old assembly (FT232B, 256 words bootloader).
    And who has a flash from cables of new assembly (FT232R, 512 words bootloader)?
  7. #3112
    Oct 2008
    On Earth
    Quote Originally Posted by alin 151 View Post
    I have a cable with vcds11.11.0 fw1.84 ft232bl
    After installation of vcds11.11.4, the cable requires update to fw1.92.
    I can update and read ATMEGA
    This is helpful?
    Yes it is helpfull indead.
    Thanks very much
    My friend magadan did this for me yet
    Good luck
  8. #3113
    Oct 2008
    On Earth
    Quote Originally Posted by magadan View Post
    This is what I need
    Thanks very much my friend
    Good luck
  9. #3114
    Aug 2012
    great forum.. lots of info.
    thanks very much
  10. #3115
    World
  11. #3116
    RF
    This is the dump extracted after update fw1.92!
    Eeprom and flash...
    The flash is similar as mine.
    Yours eeprom is already killed, look at the address 00000016 (if can transfer to a bin-format).
  12. #3117
    World
  13. #3118
    Oct 2008
    On Earth
    Don't worry about this Alin
    The flash it is good and it is the same as magadan one.
    The eeprom I knew it that it is not good.
    The VCDS softwear can upgrade just the flash in your toolbut will not change your serial with other. The eeprom remain the same don't metter what the version you use.
    And if you have a VCDS 11.11.0 eeprom this one it is blacklisted in newer version then 11.11.0
    Thanks again and Good Luck
  14. #3119
    There was on RT site unofficial installer of 11.11.4 which was working with fw1.91. It was on their server for about a week.
  15. #3120
    Oct 2008
    On Earth
    Mate
    VCDS 11.11.4 works with any firmwear ( flash ).
    BUT IT NEEDS fw 1.92 if you want to make a corect diagnostic or to not damage your car when you do any adaptation or coding.
    Take care with this.
    I can use flash 1.84 with this softwear but it is need 1.92 to works correctly.
    Good luck
