Page 20 of 854 FirstFirst ... 1015161718192021222324253070120520 ... LastLast
Results 286 to 300 of 12803
  1. #286
    Portugal
    Quote Originally Posted by bibkare View Post
    post a picture of your interface (pcb), you definitely need to re-flash atmega and maybe some other components to remove
    here are the pics
    Quote Originally Posted by Nemesiz12 View Post
    yes autoscan work perfect I use this cable with VCDS 908 on a Golf 6. I can read every control modul.
    Because Why?
    I have try to use VCDS 10.6 -> choose test
    cable wars recogniced 1 minute later Windows occures a message unknown device USB to serial. The cable do not work with the Original VCDS 10.6 and my clone VCDS 908.
    I flashed the rftl232 an the cable work again with the clone 908 sotware. I do not trust me to test it again with the 10.6
    can I test any other cloned VCDS software with a higher release?
    Maybe i have to do same as Nemesiz12 because i to upgraded it to 10.6 via roshtech site and same thing hapened to me.
    with 908 it never activated/registered then i upgraded to 10.6 and then cable was like unknown device USB to serial.
    Then uninstaled the driver and 10.6
    after a pc reboot installed 908 and the drivers and cable was recon as roshtech, but cannot activate, always says says you need licenced interface....
    Any sugestions?
  2. #287
    DK Veteran bibkare's Avatar
    B & H
    First remove stc chip like i marked in pic then you will probably need to reflash ftdi eeprom after that reflash atmega with 908 dump (flash and eeprom) configure security bits and you will be good to go. I had good experience with that kind of hardware.
    All you need: Dump VCDS 908.0: http://www.digital-kaos.co.uk/forums...ash__908.0.rar
    FTDI Eeprom for FT232BL and FT232RL: http://www.digital-kaos.co.uk/forums...tml#post816515
  3. #288
    Portugal
    forgot to say that after uninstall and then install 908 with drivers cable detecs as "ross-tech hex or key usb interface" and if i go to ABOUT in 908 it says "Dongle-only version--not activateble" before doing TEST and not pluged in car.
    After doing TEST and save and plug to car it gives a serial and still say unregistered/shareware.
    Will try remove chip monday and give a feedback.
    Thank you again.
  4. #289
    china 10.60 do now work at 100%
    do not wasting time with it
  5. #290
    B & H
    Quote Originally Posted by tk500 View Post
    Very clever solution , i suppose that you are Chinese.
    Sta ima strucnjak
  6. #291
    Sta ima strucnjak,ne seri zdravlja ti
    What this is what language? my friend pls use English
    I reverse many Chinese variants and none of these works completely. They miss something important.
    Easy to check ? just see Meas. Blocks for group 000 in engine ecu
  7. #292
    Oct 2010
    Default please help
    i have vag 912 dual-k & can interface i read so much i am scared to try. car is 2005 vw tdi can some one tell me what softweare to use. the softweare that came with it from china say it has a virus when i go to load it. thank you
  8. #293
    Nov 2010
    Quote Originally Posted by peonu2 View Post
    forget the virus, i have the seam, that ist crack vcds vers.
  9. #294
    Nov 2010
    my cable is 912
    i repair my kabel , but i get some message:
    look at pic
    which i have ft232rl or ft232rb i cannot see at the front of chip
    what is wrong
    pls. help
    Ths.
  10. #295
    xoom's Avatar
    Ylakiai
    You have with FT232RL the crapy one
    You need to do solution for 908 with FT232RL..
  11. #296
    B & H
    Can anybody confirm, as well as i know measuring blocks channel 000 can't be shown in TDI PD engines
  12. #297
    Nov 2010
    Quote Originally Posted by xoom View Post
    I want only the FW 1.83 file or what, my laptop recognized my cable as RT, but not with VCDS.
    please what file which programs?
    PonyProg2000 is correct?
    ths
  13. #298
    xoom's Avatar
    Ylakiai
    You have this good dumps ? Then you need to reprogram GAL connect remaining wires between atmega and GAL and make board for FT232BL then connect Rx/Tx/GND..
  14. #299
    Quote Originally Posted by tazman13 View Post
    Good but way too much hassle.....i was execting just to tag some wires on the GAL...
    ATF Programmer and simple schema with some wires .
  15. The Following 2 Users Say Thank You to toms4 For This Useful Post:
    BITZU (28th April, 2016), kodey (18th February, 2019)
  16. #300
    Nov 2010
    PLS help, How to make that?
