Have somebody fw1.91 for 11.11.3 and can try it with this version?
Mate stop dreaming.
If you want to erase your Atemga please use that softwears and then you'll cry.
Forget about this. All this dumps which are for free now are blacklisted in higher version. So the last version of dump which is free it is 11.11.0 So in next 11.11.1 this dump it is blacklisted and it will be blacklisted forever.
In VCDS 11.11.4 how it will be? BLACKLISTED
Good luck
Hi matty
What is this version
11.11.0-Installer*_Perfect!
Cheers
Size of it is the same like original installer, after unpack dates of files are the same too.
"805.0" ept ftdi 232 rl please
Hi all,
I have VCDS 106 cable, runs version 10.6.0, no issue. Is there a newer software I can use without reprog/reflashing anything?
J
Thanks. I could do with a spare cable so I will keep this one as is.
What is the latest reliable version out there? I have seen 11.10 for around ***8364;25
I have a 3 cables 10.6.4, 11.8, 11.10 the 10.6.4 is left on that version as backup and the 11.8 is running 11.3 but 11.10 won't run 11.10 only runs 11.3 the ftdi are BL versions what options do I have on these and what h/w are people using to flash atmega
Thanks.
Hi all, I ahve 11.11 interface at least it is written on it. It became unregistered after few sessions with internet connected, need to do the coding and adaptation... Bad luck/ or my brain is degrading with the age...forgot to disconect...
Any way it has the BL chip, and it worked fine. I am not chasing the latest version just need the 11.11.0, want to restore as it was before.
What i would like to ask if someone could point me to the place where i could download the dump for atmega, and ftdi, and also the vcds installer for that goes with these dumps. Or i can use the one that came with my interface?
And one more thing, do i really need to remove the IC8, T5, R50 for the thing to reflash properly?
I am adding pictures of my interface.
Thanks in advance.
