Page 215 of 854 FirstFirst ... 115165205210211212213214215216217218219220225265315715 ... LastLast
Results 3,211 to 3,225 of 12803
  1. #3211
    thanks to KenshinPT I solved my problem, welds are perfect I've done a lot in my life, the problem of flux pcb dirty, I cleaned it with the triellina and now everything works perfectly, thank you in a special way KenshinPT, but also bibkare, their two are great people.
  2. #3212
    DK Veteran KenshinPT's Avatar
    PT
    Quote Originally Posted by giuseppe1374 View Post
    We are always learning!
    In my humble opinion, what makes someone expert is not making the same error twice
    I believe, that next time you will pay more atention about the flux cleaning
    Good luck.
    Did it help? Push Thanks below
  3. #3213
    hello!
    VAG-COM ,WCDS process collection i needed.
    sorry for my bad english !
    thank you !
  4. #3214
    Apr 2011
    Thank you, this thread was very helpfull!
  5. #3215
    Member pauleemor's Avatar
    lanarkshire
    Default vag 113 help
    hope someone can help vag 113 when connect to car it shows attached thanx
  6. #3216
    Oct 2008
    On Earth
    Quote Originally Posted by pauleemor View Post
    Reinstall the VCDS anbd do the interface TEST again
    If in ABOUT it is UNREGISTRED ....you had bad luck
    The ATMEGA eeprom it was erased
    Good luck
  7. #3217
    Member ironderek's Avatar
    I had fix RL cable and install software with loader on XP machine-everything works perfect, but when I try to install to same software on Windows 7 64bit I've got error message "Wrong Filesize", any idea why, and how to fix it? Cable works ok on Windows XP, but cannot install it on W7 64bit???
  8. #3218
    Oct 2008
    On Earth
    Quote Originally Posted by ironderek View Post
    From what i know the loaders for interface with FTDI RL are JUST for Windows 32bit not for 64bit.
    Good luck
  9. #3219
    RF
    Copy the file "vcds.exe" from the 32-bit program, in the folder on other computer where there is a 64-bit program. Also you can launch the program on the 64-bit computer using a loader.
    Or select from the menu point "To install the 32-bit program on the 64-bit computer". This menu appears at the beginning of VCDS program installation.
  10. #3220
    Apr 2011
    Can any one help me repair my vag com cable that was connected to internet?
    The cable uses FT232BL.
    Thanks in advance!
  11. #3221
    Quote Originally Posted by magadan View Post
    Thanks magadan, but this is my problem when I try to use/launch loader on 64bit OS I've got error message "Wrong Filesize". To same loader on XP 32bit OS works fine.
  12. #3222
    RF
    ...but this is my problem when I try to use/launch loader on 64bit OS I've got error message "Wrong Filesize"....
    The file "vcds.exe" for 32-bit system and the file "vcds.exe" for 64-bit system aren't equal on the size. These files have different codes in a random access memory. Therefore the loader doesn't work.
    Also the loader always is calculated for one and the same of the file "vcds.exe". If to use a loader for other file (other bit-sistem, other version program, non windows-program etc.), you will receive this error.
  13. #3223
    Middle earth
    Hello. I need some help regarding the VG.B 2011.07.01 FTDI 232BL interface if you don't mind.
    It showed unregistred, that's why I tried to update 1.92 FW.
    I connected it to an Atmega 162 chip (based on a description I found). It had a continuous red light, but it stopped a bit later.
    I decided to wait a bit, but nothing happened.
    When I started to read with with the "pony-prog" is showed "device not found".
    In the meantime I found an other picture\description on the net which had no gal chip at all, but it had an older cicruit board "VG.A".
    Shall I try to flash based on this second description, or do you have any idea?
    Thanks for your time, waiting for your answer.
    http://www.digital-kaos.co.uk/forums...cds-no-gal.rar
    http://imageshack.us/photo/my-images/259/dsc0503t.jpg/
  14. #3224
    PT
    Quote Originally Posted by beriv View Post
    ImageShack® - Online Photo and Video Hosting
    If you have a BL chip you don't need to remove or reflash the GAL.
    But you need to remove the STC chip, a resistor and the transistor.
    Then, reflash FTDI232BL and ATMEGA.
    Good luck.
  15. #3225
    Middle earth
    Ok thanks for the hint
    I know how to reflash ATMEGA, but I could use some help, how to refash FTDI232BL
    Can you help me please?
