Page 21 of 854 FirstFirst ... 1116171819202122232425263171121521 ... LastLast
Results 301 to 315 of 12803
  1. #301
    Nov 2010
    I have the same problems as you
    I tested v. 106 and my cable does not work anymore.
    How did you do?
    what program? which file?
    Please help
  2. #302
    Gonna give up now anyway as my car needs the newer software as 908 don't talk to the modules. GAL is an issue.
    Cable up for grabs for a few quid if someone wants to take the risk and fix it??
  3. #303
    Nov 2010
    Hi.
    I have bought 106 Chinese cable. It works with VCDS106 (shipped with cable) and communicates with my car without problem. But it also says "Unauthorized/Anauthenticated" version in About dialog.
    Does anyone know how to fix this?
    I'm quite a new with VCDS and didn't play a lot with it, so I don't actually know if there are some restrictions while the program is "Unauthorized". The only thing i have noticed is that descriptions for option bits are not shown while trying to read and interpret their meanings.
  4. #304
    Oct 2008
    On Earth
    Quote Originally Posted by vmadunic View Post
    Hi.
    Hi m8
    Do this procedure everytime before you run the VCSD softwear, 1 Plug the interface into the car
    2 Plug the interface into the USB
    3 Run the softwear.
    If you close the softwear, before to run again, please do the procedure again, step by step.
    All thanks go to my good friend ipejasinovic.
    Good luck
  5. #305
    Nov 2010
    Thanks, I'll try that and will let you know whether this solved my problem.
  6. #306
    Oct 2008
    On Earth
    Ok
    I had same problem but i read the procedure posted by my good friend ipejasinovic here in DK and everything's working like a charm now.
    I hope for you will be the same.
    Good luck
  7. #307
    Hi guys,
    I have one 704 and one 812 which are both bricked.
    Do I start by removing the components and try to flash the atmel chip?
    Here are the interfaces.
  8. #308
    DK Veteran bibkare's Avatar
    B & H
    Quote Originally Posted by gkoutsis View Post
    Hi guys,
    As well as i can see both interfaces are with FT232BL which is good, first remove components (very well explained in earlier posts) then flash atmega
  9. #309
    Components removed
    I am looking for the 812.4 ept file. I tried the romanian link but I all I get when I click on the download button is ~~~~
  10. #310
    B & H
    Components removed
    You have here .ept for FT232BL http://www.digital-kaos.co.uk/forums/f152/vcds-10-6-0-work-witch-chinese-clone-165830
    /index4.html#post816515
    Download button is ~~~~ yea yea take it
  11. #311
    Thanks for the swift replies!
    Ijust programmed the VCDS 908 FT232BL.ept with Mprog and the interface is recognised just fine (the 812.4)
    Which version should I use now? 908 or 812.4?
  12. #312
    B & H
    If you flashed atmega with 908.0 dump then you can use VCDS 908, if i helped you just hit thanks button
  13. #313
    I am looking for a good link to download the 908 version.... any help?
  14. #314
    Quick Update:
    Both interfaces are now recognised as Ross-Tech etc etc VID 0403 and PID FA20.
    Initial testwith vag com 908 show interface found but not plugged in the car.
    Once I plug it in the car it's not found.
    remove it, close the program, plug it back in the usb and run the program will discover it again just fine.
    Any ideas?
  15. #315
    812.4 upon test shows that:
