Page 220 of 854 FirstFirst ... 120170210215216217218219220221222223224225230270320720 ... LastLast
Results 3,286 to 3,300 of 12803
  1. #3286
    Oct 2008
    On Earth
    Quote Originally Posted by 1 6 D View Post
    mattydr67, do you have dump and ept file for chinese 11.11.3 RL cable?
    If you mean the dump which works with the VCDS 11.11.3 softwear made by chinese, the answear it is I don't for simply reason that the Chinese softwear it is "such a bad"
    I have my dumps for VCDS 11.11.2, VCDS 11.11.3 and VCDS 11.11.4. The softtwears works with tools with BL/BM abd RL without any modification or loader. It's tottaly diffrent then Chinese one. What test I did in this time with all versions I made it in comparation with a genuine tool. I can say that there's no diffrence between them.
    Good luck
  2. #3287
    Nov 2010
    Quote Originally Posted by Artilect View Post
    The connection is 1:1 to ISP connection on BeeProg
    My cables (MOSI - GND - RST - SCK - MSC)
    Cmd to program in one click with avrdude (change FLASH.HEX and EEPROM.HEX)
    avrdude -c usbasp -p m162 -euV -U flash:w:FLASH.HEX -U eeprom:w:EEPROM.HEX -U lfuse:w:0xcd:m -U hfuse:w:0xdc:m -U efuse:w:0xf9:m -U lock:w:0xff:m
  3. The Following User Says Thank You to tr3ce13 For This Useful Post:
    ni88l3r (8th January, 2017)
  4. #3288
    I have a problem with RL cable, I have removed GAL, uploaded 11.11.0 dump. On 64 bit loader doesn't work. TEST by VCDS doesn't find interface, what should I check to correct working of this cable?
    LED is green, not blinking red, it's still green.
  5. #3289
    Oct 2008
    On Earth
    Try in 32 bit.
    The loader dosen't work in 64 bit
    Good luck
  6. #3290
    Mar 2009
    THANKS!!!!!!!!!!!!!!
  7. #3291
    galiza's Avatar
    Jun 2011
    Default VagCom 607.3
    Hello, I have a clone of 607.3 interface, but I haven?t registered software.
    Is there a cracked version 607.3?
    It is better to arrive 10 minutes early, than to be bored all the way.
  8. #3292
    It's very old version. Now there is 11.11.0 for free possible to download, probably You have to reflash ATMEGA and FTDI
  9. #3293
    Jul 2012
    Hello
    Well, I have a new Chinese clone 11.11.2 (the previous one I broke).
    Of course, first autoscan and this error.
    I want to install, the 11.11 is in the forum.
    But did not understand English very well get lost.
    Can you give me I have to desolder for installation?
    I have BL and Atmega 162 chip
    greetings and thanks
  10. #3294
    Oct 2008
    On Earth
    Quote Originally Posted by pomarada View Post
    Hello
    99.99 of Chinese sellers are cheaters.
    You was cheat by them
    They haven't this dump and not other higher then 11.11.0
    In this tools you have nothing tounsolder ,you have to reflash the Atmega with the proper dump and maybe the FTDI but for sure you haven't to unsolder anything (STC)
    Good luck
  11. #3295
    RF
    Quote Originally Posted by mattydr67 View Post
    In this tools you have nothing tounsolder ...
    You aren't absolutely right, the doctor. I repaired recently the Chinese cable of version 11.11.3. He was accurate on chip FT232R. Inside atmega162 was eeprom which worked with VCDS 11.11.3 program. Only it was necessary to use a loader to change ChipID a cable.
  12. #3296
    Oct 2008
    On Earth
    Quote Originally Posted by magadan View Post
    I know about that Chinese sh..t and "I cannot say that it is exist". I had one to test. Now i changed the Atmega dump with mine No loader need.
    This Chinese softwear has a lot of bugs.
    But you allready know this.
    Good luck
  13. #3297
    Brest BY
    What has changed in the dump?
    p.m.
  14. #3298
    Jul 2012
    Hello
    Well, I have wired the Atmega, a USB ISP ASP, but I encounter some problems and I'm doing something wrong
    - Installed drives, and usb isp
    - I run, read in the extreme burner and gives me error reading of power.
    -I check the 7805 and 5voltios fail.
    The connections, the Atmega are fine.
    The 5voltios, the sack of usb-isp
    Run, visrtual of xpmode machine.
    What am I doing wrong?
    Clumsy manual is there, for extremeburner?
    Greetings
  15. #3299
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Hello
    Greetings
    are you putting 12v to 7805?
  16. #3300
    ahadi's Avatar
    [QUOTE=mattydr67;1721956]99.99 of Chinese sellers are cheaters.
    this is not correct, work with original is more easy than clone . 99.99 want save money buying clones ,90 of them dnt know the difference .
