Page 221 of 854 FirstFirst ... 121171211216217218219220221222223224225226231271321721 ... LastLast
Results 3,301 to 3,315 of 12803
  1. #3301
    Jul 2012
    I am putting 5v
  2. #3302
    Oct 2008
    On Earth
    [quote=ahadi;1724203]
    Quote Originally Posted by mattydr67 View Post
    99.99 of Chinese sellers are cheaters.
    You was cheat by them
    this is not correct, work with original is more easy than clone . 99.99 want save money buying clones ,90 of them dnt know the difference .
    20 of DKs are leachers .
    I don't know what you want to say but when a seller told you that he/she sell you a vCDS 11.10 for sure he/she is lying you.
    Anyway I don't say that you cannot works with a clone but more peaple are cheated by Chinese becasue they don't know what to buy or they haven't information.
    What I want to say that in China the last clones it is VCDS 11.11.0
    Well it is one which works with a chinese softwear ( cracked one ) fo VCDS 11.11.3 but this one have a lot of bugs. Bad cracked i suppose.
    But this is not my problem.
    Anybody can what they want to do.
    So this is my opinion and if you're agree with me it is Ok if you aren't it is OK too
    Good luck
  3. #3303
    Jul 2012
    I just put votios d12 and now LED lights.
    Checking votaje 11.26v will arrive at 7805.
    The funny thing is that the transformer sends 12.32v offline.
    The extreme still gives me the error
  4. #3304
    Oct 2008
    On Earth
    Quote Originally Posted by pomarada View Post
    Did you solder together the GND of Programmer with the Power GND?
    Good luck
  5. #3305
    Jul 2012
    Good luck
    Hello
    Attempt to of two ways.
    - The output 5v programmer, pin 2 positive, and pin4 mass.
    - Also with 5v source, independent power
    With 5v, do not LED lights up, the vag
    Then change to 12 volts independent. With 12 volts if you light
    Is there any problem if 13voltios?
    Greetings and thanks for the help
  6. #3306
    connect the 4 wires between programmer and atmega, the GND of programmer to GND of VCDS, power on +12 V VCDS, plug-in usb cable. Open eXtreme Burner, open file[s], set and check good fusebits, write...
    If not, check the +5v after 7805. If is OK, you make a mistake, or your programmer is not OK..or..atmega locked/damaged.
  7. #3307
    Firmware 1.92
  8. #3308
    Mar 2012
    It is possible to program the NEC?
  9. #3309
    Oct 2012
    Default VCDS kills cable
    Hi there
    I'm new here and as Ross-Tech seems to take copy cables more seriously, it killed my VCDS cable. I hope I get mine working again with these tutorials.
    Otherwise, I'll bother you...
    Thanks for helping.
  10. #3310
    Oct 2008
    On Earth
    Quote Originally Posted by tricoredc17 View Post
    It is possible but no dump for NEC
    For the the solution if your tool is erased it is to buy other one, maybe with Atmega this time.Sorry you have no choice.
    Good luck
  11. #3311
    Im looking for good quality PCB for VCDS 2-3 pcs.
    Please link or PM,
    Thanks,
    Boras
  12. #3312
    Oct 2008
    On Earth
    Quote Originally Posted by Boras View Post
    Please link or PM,
    Thanks,
    Boras
    Take a look of this once
    Good luck
  13. #3313
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    I have reflashed atmega and see pic for error is this just a case of firmware too old for v11.11? ftdi is bl type
  14. #3314
    bad eeprom
  15. #3315
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    bad eeprom
    which eeprom
