Does anybody have installer of VCDS 10.6.5 PCI or/and DRV version?
Or there wasn't this versiona, only MFT?
Hi gents
I have a 11.11 hex-can clone and it is not showing as unregistered in vcds. I was not connected to the internet when using the cable but somehow it is now only good for clearing error codes.
I have found the 11.11 dump but how the hell to I flash the cable again to get it working.
Thanks in advance
Sully
Well I will tell you and for all members that you it is not important to be connected to the internet in hte same time with diagnostic session.
It is important to not be connected to the internet ever.
Because when you are at home and your computer it is connected to the internet network the VCDS servers check your licencens in background and if item detects in you computer a blacklisted serial it will "attack" your clone.
It let something in your computer and girst time you'll plug the interface to the USB and try to connect to a car the serial in MCU will be erased and your toll will never work good.
That's why you have this issue.
To flash it back you have to read to seee what you need and much more of that you need to have skills in soldering/unsoldering smd components
Good luck
Hi Pal
thanks for your reply, I had added ross-tech.com to my hosts file but guess I should have logged what ip's vcds was trying to connect too.
I have no problem soldering did a few xbox's and wii's but sounds like it is too much hassle and it's best to get another clones. I have read through a lot of this thread and post #95 has a tutorial but it is for an earlier version will this still work for the newer cables?
What is important is how do you stop it happening again via firewall blocking vcds or other blocking option.
Sully
hi
I have cable with pins to Atmega with BL chip.
I've flash only Atmega with some dump
VCDS 11.2.0_soft&dump_for_china-clone_FT232RL
My cable started ? I?ve read engine status well,
but after few minutes I've got an error.
Interface Status = -2
Interface not Ready !
Look for an attachments.
Could any body know what happened with my cable?
Sally the tutorial it is the same. I mean to flash Atmega ir is the same
The most important thing it is what kind of tool you have because if you red in one of them you need to remove 3 components, in other you don't
Share pics with your both sides of PCB please.
Let me take a look please
Good luck
I will post pics tonight of the pcb, should have take some when I openned it to check if it fried.
Hi1 I make an update to 1.92, in the vcds test windows it's ok
When I testet on my car, I have this error:
What it's wrong?
In new version after 11.11.0 the drivers it is rolled back to 2.06.02 as in the previos versions of 11.11.0
Why?
Because VCDS 11.11.0 had a lot of bugs and probably this is caused by the driver version
Who knows?
Good luck
Mate what problem do you want to solve?
You ahve dump for VCDS 11.11.0 and you try to use the VCDS 11.11.4 version
Reflash your tool again and use the VCDS 11.11.0 version not other higher version.
For VCDS 11.11.4 version you need a not blacklisted serial ( dump ) not just the firmwear
Good luck
