Everythings fine, thanks!![]()
Last edited by liosque; 1st November, 2012 at 10:11 PM. Reason: Everything is fine thx
Only installer? Or with dump?
Last edited by liosque; 1st November, 2012 at 10:11 PM. Reason: Everythings fine, thanks! :)
đđĐđß$đĐßđßđßđđääđłldkf>>;*;ßßߤߤ;>>;>ßߤ]$ß$÷÷×ßß]¤¤¤]ß$$[ß[¤ĐĐß[ß...
Ept for RL you can find it in this forum
It was shared for many times.
If you don't find it please ask again and tommorrow I will shared again for you. If no one who have it and can shared now will not do it.
By the way the dump you shared it is not for VCDS 11.11.3 it is for VCDS 11.2 or VCDS 10.6.4 or for previos version of this once.
Good luck
Hi All,
Would anyone be able to actually sell a good working cable with the software? UK preffered
Hy every body
can any one crack this vcds software for me or creat one loader?? it 11.11.1 version (french)
Download VCDS-FRM-11111-Installer.exe from Sendspace.com - send big files the easy way
Maybe somebody can helps me. I bought a few pcs VCDS 11.11.0 from www.ecutool.com recently. I downloaded the software directly from the link they sent me. I have problem with install driver.Windows can't find them.
I tried on Windows XP, Windows 7.
There is different PID (FA30) in device and in RT-USB.ini (FA20,FA23,FA24,FA25).
I found some file to reprogramming FTDI, so I did it. Drivers installed well but VCDS can't recognized interface.
Please help me.
In attachment is screen shots where you can see different between PID in device and ini file. I wanted to see that I tried changed PiD in RT-USB.ini file too but it doesn't work too.
Use this:
1. Unpack it and replace the one you have in VCSD folder.
The try to install the driver
Good luck
It is not necessary to experiment. It can accelerate breakage dump atmega or FT232. The person has cable and the program from different sets. Let will communicate with the seller of a cable and will ask it the program.
You want to break what protection in the program? What parameters of a cable aren't pleasant to the program?
