Page 229 of 854 FirstFirst ... 129179219224225226227228229230231232233234239279329729 ... LastLast
Results 3,421 to 3,435 of 12803
  1. #3421
    There is a new version of VCDS, Beta 12.10.0, I haven't installed it yet.
  2. #3422
    Oct 2008
    On Earth
    Quote Originally Posted by 1 6 D View Post
    Yes it is Beta version.
    Do you have a genuine tool to use it?
    No...so don't use it becasue will erase your Atmega
    Good luck
  3. #3423
    Sep 2010
    Quote Originally Posted by teerak2uk View Post
    I know its wrong I've not changed anything but looking at some screenshots from ponyprog but the layout is different
    Low fuse: CD
    High fuse: DC
    Extended fuse: F9
    Lock fuse: FF
  4. #3424
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by noogi View Post
    Low fuse: CD
    High fuse: DC
    Extended fuse: F9
    Lock fuse: FF
    yes tried that with v11.11 but didnt work
  5. #3425
    Print screen with "Test" please and with "About"...
    If test not OK, K1=OK, K2=OK and nothing about CAN, eeprom is wrong.
  6. #3426
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    all up and running now thanks to all that helped here are screens of soft h/w etc and files i used to do it with.
    ***Note: the 3 wires going to the under side of the board are ground wires for the avr interface***
  7. #3427
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    These are the other files with pics that i used
  8. The Following User Says Thank You to teerak2uk For This Useful Post:
    ni88l3r (8th January, 2017)
  9. #3428
    Member ironderek's Avatar
    Couple days ago I've got VCDS Adako 10.6.5 Polish language version dump. I flashed my BL cable and tried to test it, but after 2 full scans cable becomes unregistered during third auto scan. Any idea why? Is it bad dump?
  10. #3429
    Oct 2008
    On Earth
    Quote Originally Posted by ironderek View Post
    Flash it back and install the softwear in a computer that you'll cannot conect to internet ever first
    The if the interface will be erased again this menas that you have a bad dump
    Good luck
  11. #3430
    DK Veteran KenshinPT's Avatar
    PT
    Matty is right. If you own the good 10.6.5 Polish dump you need to be careful with the internet.
    Did it help? Push Thanks below
  12. #3431
    Aug 2011
    can the license be extracked from D1 D2 D3 files? many thanks
  13. #3432
    Oct 2008
    On Earth
    Quote Originally Posted by andrius View Post
    NO
    Guys if it was such simple way now the Ross-tech it was broken
    Adn the guys who can do this as well
    So please stop dreaming
    Good luck
  14. #3433
    Sep 2012
    i see the new software of VCDS lite v1.2 is out by Ross-Tech can anybody please help me with a keygen or a loader for this
  15. #3434
    Oct 2008
    On Earth
    Quote Originally Posted by BrendanT View Post
    The last loader was for VCDS Lite v 1.0
    This one was made my old and very good friend Aminebot
    No KeyGen and no Loader after this last good one
    Try a new HEX-CAN interface if you like to have more function for the VCDS
    Good luck
  16. #3435
    xoom's Avatar
    Ylakiai
    FW is in: HCC184.bin, HP184.bin files.. Its encrypted and it not contains eeprom part imho
    Those files can be decrypted via VCDS cable.. like that you can have newest FW but not eeprom part..
