Page 230 of 854 FirstFirst ... 130180220225226227228229230231232233234235240280330730 ... LastLast
Results 3,436 to 3,450 of 12803
  1. #3436
    Aug 2011
    but the data from eeprom is encrypted and kept in D1 D2 D3 files, as i see. so you have Flash and Eeprom in your VCDS folder you dont need to decrypt FW, just write old FW, fully lock atmega, and update, here you have the new FW
  2. #3437
    Quote Originally Posted by teerak2uk View Post
    Working now?
  3. #3438
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Working now?
    Yes working now
    The problem was when selecting the files flash, eprom from the tabs iit was not selecting properly so selected via filem/open eprom etc from the top menu
  4. The Following User Says Thank You to teerak2uk For This Useful Post:
    allent (17th December, 2013)
  5. #3439
    xoom's Avatar
    Ylakiai
    Quote Originally Posted by andrius View Post
    i agree that some authentification data is in d1 d2 d3 files.. by these files VCDS.exe shows serial number in About window.. but how its doing that i dont know.. maybe there is just some data from eeprom not all. And if you want to get FW you no need to lock atmega.. just leave it unlocked.. so after update you can read atmega and have Decrypted Flash side of atmega.
  6. #3440
    Fw (aka FLASH part of atmega) are posted here, 1.84, 1.92... few or more pages earlier. Signature/serial (aka EEPROM) for free is only for 11.11.0.
  7. #3441
    Aug 2011
    the most interesting thing for me is, that i am preaty sure, that VCDS reads EEPROM in unsecured channel, so if you have logs, you should see the data beeing read. but i dont have a good usb sniffer to test my ideas maybe someone could recomend me one?
  8. #3442
    xoom's Avatar
    Ylakiai
    im loged it via Logic Analyzer .. on TXD RXD lines of FT232 chip, it sends data but its encrypted for sure.. and it allways different..
  9. #3443
    parla
    do not know why but they are loaded brush eeprom 10.64 and 11.3 beta. Now test was 11.11 new chip to be more stable.
    has given some good results this version.
  10. #3444
    If I have clone VCDS 11.2 which is self-repairing(unplug from OBD, plug again and serial is green back), can I update only FW to 1.91 or 1.92 and it will be still self-repairing?
  11. #3445
    Top Poster + mladen76's Avatar
    By the see
    Why woud you even need to update firmwire mate.
    Not nesesery,ok,let us say you update firmwire for example what good it is when you still have 11.2 version of program??
    11.11.0. Still use 1.84 firmwire and no need to think about that mate...
  12. #3446
    I want to check newer file from VCDS 11.11.4 for RNS510 navigation, I know that there is some new adaptation channels written and I want to read them. I don't want to make this clone "not self-repairing".
    FW in dump for my clone and for 11.11.0 is the same, so self-repairing is in EEPROM maybe?
  13. #3447
    DK Veteran KenshinPT's Avatar
    PT
    Quote Originally Posted by xoom View Post
    Just one tip, lots of guys here know this trick but are not sharing.
    Use Ollygbd you will be amazed with what you can see
    Tip 2: Test with a known EEPROM and try to find where those values are passed.
    For example. Use 11.11.0 and try to find if the decrypted content of the EEPROM can be seen in Olly.
    SPOILER ALERT: Yes it can be seen
    This trick is only used to read the EEPROM from original or clones VCDS cables... This trick is not to create dumps that will work in newer versions of VCDS.
    Regards.
    Did it help? Push Thanks below
  14. The Following User Says Thank You to KenshinPT For This Useful Post:
  15. #3448
    Jun 2011
    Quote Originally Posted by meteor80 View Post
    Hello.
    Maybe someone have dump for my interface.
    It was 11.11.3.
    Interface without GAL
    Is there any dump that will work with this interface?
    i can make this cabble!
    i have dump,haha
  16. #3449
    Aug 2011
    but if you have eeprom you can write it and have a copy cabel or not?
  17. #3450
    Mar 2012
    Default Who can help me has lira and to schedule(program) atmega and fti?
    HELLO I am francais who can help me has lira and to schedule(program) atmega and fti?
    I possede April usb I how look for to read and has to schedule(program) atmega 162 and the fti can help me?
    What are the programs has to use?
    Thank you for reponse
