Page 231 of 854 FirstFirst ... 131181221226227228229230231232233234235236241281331731 ... LastLast
Results 3,451 to 3,465 of 12803
  1. #3451
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by master933 View Post
    HELLO I am francais who can help me has lira and to schedule(program) atmega and fti?
    I possede April usb I how look for to read and has to schedule(program) atmega 162 and the fti can help me?
    What are the programs has to use?
    Thank you for reponse
    First post pictures from both sides of pcb from your vcds cable
  2. #3452
    Mar 2012
    Default Reading atmega and fti and cablage?
    I look for the cablage to read atmega and the fti
    Thank you
  3. #3453
    Nov 2012
    I can help you translate if you want. Je peux t'aider ? traduire tes messages si tu veux, ils ne sont pas tr?s claires pour le moment.
  4. #3454
    Dec 2012
    Default test
    test plus 20zeichen
  5. #3455
    Oct 2012
    Odense, Denmark, Denmark
    mange tak den var til stor hj?lp
  6. #3456
    Newbie Arno's Avatar
    Germany
    VCDS with different language:
    Vag-Diag : VAG diagnostic tools
  7. #3457
    Quote Originally Posted by Arno View Post
    But free promised updades can and to not be, earlier the bought adapters any more do not work with 11.11.4 software.
    Not all sellers constrain promises...
  8. #3458
    Germany
    Quote Originally Posted by XPS View Post
    I got update 11.11.4 German free without problems.
    Update for English version must be paid.
  9. #3459
    DK Veteran aminebot's Avatar
    Oct 2008
    Algiers
    I got a small problem with this update , but we started sending this update 1 week ago.
    send me your email by PM.
  10. #3460
    Originally Posted by beriv
    Hello. I need some help regarding the VG.B 2011.07.01 FTDI 232BL interface if you don't mind.
    It showed unregistred, that's why I tried to update 1.92 FW.
    I connected it to an Atmega 162 chip (based on a description I found). It had a continuous red light, but it stopped a bit later.
    I decided to wait a bit, but nothing happened.
    When I started to read with with the "pony-prog" is showed "device not found".
    In the meantime I found an other picture\description on the net which had no gal chip at all, but it had an older cicruit board "VG.A".
    Shall I try to flash based on this second description, or do you have any idea?
    Thanks for your time, waiting for your answer.
    http://www.digital-kaos.co.uk/forums...cds-no-gal.rar
    ImageShack***174; - Online Photo and Video Hosting
    Quote Originally Posted by KenshinPT View Post
    If you have a BL chip you don't need to remove or reflash the GAL.
    But you need to remove the STC chip, a resistor and the transistor.
    Then, reflash FTDI232BL and ATMEGA.
    Good luck.
    It is a pitty that user borysgo2 uses other's feather to make himself look nicer.......
    no GAL solution was developed by me and first published long long time ago on garageforum.co.uk .......
    I did it for all people not only for borysgo2.......
  11. #3461
    xoom's Avatar
    Ylakiai
    Is that solution works well? Becouse i think that it should be there .. its like doing some de/multiplexing thing.. But im not studied it very well So ignore this post if its nonsence
  12. #3462
    Quote Originally Posted by xoom View Post
    look at the attached photo and its date, chinese even started to produce them without gal
  13. #3463
    xoom's Avatar
    Ylakiai
    That doesn't mean that its better it's mean it's cheaper
    i think AGK can explain more what this PLD does
  14. #3464
    Oct 2008
    On Earth
    Guys
    Mr. Sky59 it is the owner of this solution for the interface whithout GAL
    The chines copyed his solution and make now an interface without GAL
    But as Mr. Xoom said the solution it is cheaper but this solution cannot repalce all GAL functions ever
    Good luck
  15. #3465
    RF
    Quote Originally Posted by sky59 View Post
    Chinese use not your decision. Chinese changed a flash atmega.
    In these a cable won't suit flash to the old version.
