Page 234 of 854 FirstFirst ... 134184224229230231232233234235236237238239244284334734 ... LastLast
Results 3,496 to 3,510 of 12803
  1. #3496
    DK Veteran cocoh's Avatar
    Jun 2009
    Quote Originally Posted by hcsaibot View Post
    ... and flash the GAL
    I guess I'm blind but I can't see that U9!!
    a small guide how to do it?
  2. #3497
    Oct 2008
    On Earth
    All 3 are newer interfaces with RL
    Take a look at this post
    http://www.digital-kaos.co.uk/forums...ml#post1795425
    Mate
    cocoh interface it is with BL so know you figure it out why you don't need to reflash GAL
    Good luck
  3. #3498
    Quote Originally Posted by mattydr67 View Post
    Liviu have right
    In the interface with BL/BM you don't need to reflash GAL/ATF
    In one kind of RL tool you don't need to reflash GAL either
    In one kind of BL/BM tools you don't need to remove STC ( U9 )
    Good luck
    Can you explain it please, with the RL tool and don?t reflash the GAL
  4. #3499
    In that post interface are with RL, interface of Cocoh are with BL...
  5. #3500
    Sorry I've just seen it yet
  6. #3501
    Quote Originally Posted by cocoh View Post
    On the left of 7805, above of 6.000 MHz resonator, in photo "vag...02.jpg"
    Have 20 pins, 2x10
  7. #3502
    Jun 2009
    so it is better to remove the GAL?
    I'm confused now...
  8. #3503
    No, only STC chip..
    20 pins..on 2 rows, GAL have 20 pins, too, but is PLCC (4x5)
  9. #3504
    I'm confused now...
    when it work with GAL i wouldn?t remove the GAL
  10. #3505
    Oct 2008
    On Earth
    Yes mate
    There are on market some kind of tools with RL that you don't need to reflash GAL
    Simple take a look of this one. You don't need to remove or reflash anythingelse then Atmega and FTDI if you need
    But no remove STC or reflash GAL
    Good luck
  11. The Following User Says Thank You to mattydr67 For This Useful Post:
    allent (17th December, 2013)
  12. #3506
    Yes mate
    Good luck
    Thank you Mate
  13. #3507
    thank you mate!
  14. #3508
    Thank You Mate!
  15. #3509
    Polish VCDS dump which is free now is for VCDS AKP 10.6.5
    One person give me this link to dump with installer, FW is 1.78 and VCDS have to update FW to 1.84
    http://rapidgator.net/file/30549895/robinhood.rar.html
  16. #3510
    Dec 2012
    hi ,everyone i have a VCDS interface with ftdi ft232BL chip ... i reflash atmega (908 dump ) and it worked ... next day i tested a vw golf : first test it wrorked ok , second test , my laptop (never ever connected to internet) dosen't recorgnise the interface , i mean that i pluged the interface in usb port and dosen't appear in device manager (the source transistor seems to burn , but i measured and the result was only 5 volts got out of it that seems normal to me ) , i have another interface that broke the same way ... and i couldn't get to the problem :| what can i do ? it's a problem that i couldn't find anyware on internet ... please help me ! (sorry for my bad english)
