Page 237 of 854 FirstFirst ... 137187227232233234235236237238239240241242247287337737 ... LastLast
Results 3,541 to 3,555 of 12803
  1. #3541
    DK Veteran KenshinPT's Avatar
    PT
    Quote Originally Posted by 1 6 D View Post
    KenshinPT was on forum in half of December last time.
    I was trying to open VCDS with olly but I have problems. With chinese 11.11.3 and older 908 too.
    I'm back
    Sorry for being away for so long.
    Regards.
    PS -> And yes... You can extract 100% the EEPROM with Ollydbg or USB sniffer or PE-Tools and a brain
    Did it help? Push Thanks below
  2. #3542
    Jan 2013
    Default Hallo
    My name is Martin, I would like to know the HEX-CAN. I'd like to read through your posts here, if that's possible. Thank you.
  3. #3543
    Oct 2008
    Croatia
    Hi, i have one qestion:
    I have cable 908,now i have instaled version 10.6.4,and now it says that status ok ,but not plug in car...
    Any solution or this version does not work with 908 cable? if not what to do next? only installing 908 software or do i have to use programer to make dump to 908?
  4. #3544
    Oct 2008
    On Earth
    Quote Originally Posted by ghostryder23 View Post
    First of all serail from 908 it is blackliste in futhure versions
    Second you must plug it into the car
    Then my advise it is do not try becasue it will erase it.
    If you did it maybe the licence is allready erased.
    Try again with 908 softwear and you'll see if it is working
    You can upgrade it if you want. Any VCDS tool can be upgraded
    Good luck
  5. #3545
    RF
    Quote Originally Posted by sky59 View Post
    It is a pitty that user borysgo2 uses other's feather to make himself look nicer.......
    no GAL solution was developed by me and first published long long time ago on garageforum.co.uk .......
    I did it for all people not only for borysgo2.......
    Quote Originally Posted by magadan View Post
    Chinese use not your decision. Chinese changed a flash atmega.
    In these a cable won't suit flash to the old version.
    Excuse me. I wasn't right. The diagram of this cable is completely identical to the diagram of mister sky59.
    I quite recently received confirmation.
    Happy New Year all !!!
  6. #3546
    Friend have gaved me a VAG118 clone to update. I have unsoldered STC, R50,T5. I have flashed atmega with 11.11.0 dump, when tried it with VCDS, there is information that FW is unknown and VCDS can't upload FW 1.84, what could be wrong with it?
  7. #3547
    Oct 2008
    On Earth
    Mate did you used eeprom + firmwear when you upgrade?
    Set the fuse bits?
    Good luck
  8. #3548
    I use eeprom and flash, but I haven't changed fuses. I will try in second.
    EDIT:
    Still FW unknown
    I used
    Low fuse: CD
    High fuse: DC
    Extended fuse: F9
    Lock fuse: FF
    previous was:
    Low fuse: CD
    High fuse: DC
    Extended fuse: FB
    Lock fuse: FF
    My own cable work with the same settings and files without problems.
    Next friend gave next clone to update and there is problem too, at first after soldering there were errors with connections but it can read and write something. After flashing cable is death. LED is not working at all. This cable don't have STC and it was on RL VCDS 10.63 version.
  9. #3549
    Oct 2008
    On Earth
    Try CD, DC, F9, CC
    Take a look if the 7805 it is good
    Or Atmega it is blocked
    Take care if you playing with fuse bits
    Good luck
  10. #3550
    CC or FF is the same about FUNCTIONALITY. CC mean that Atmega cannot be read.
  11. #3551
    Maybe I have to solder back one of the elements? Resistor only?
    When I read dump after flashing it's ok, but when I do TEST in VCDS, there is info about unknown FW version still, it can't be updated by VCDS.
    Or I have to unsolder GAL? But I'm not sure if this will delete some functions? Or everything will work, on K-line and CAN?
  12. #3552
    For Ft232B version, it work with extract STC, diode/reseter/transistor and one resistor... reflash atmega and/or FT232.
    For FT232R version, must extract STC, diode/reseter/transistor, R50,R51, GAL - for reprogramming, reroute 3 wires and reflash too FT232 if is necesary and ATMEGA.
    Will work with loader.
  13. #3553
    Excellent summary!!!!
  14. #3554
    Jan 2013
    Somebody have 1.84 firmaware for 11.11 ??
  15. #3555
    Hello all,
    I have a chinese VAG 11.11 interface that currently is not working as I receive the message with "license". Could someone give me all the information on how to repair it? Can I find somewhere all the steps to repair it? Do I have to buy some new devices? I would appreciate a response for a beginner with each step to make. Thanks in advance
