Page 24 of 854 FirstFirst ... 1419202122232425262728293474124524 ... LastLast
Results 346 to 360 of 12803
  1. #346
    Oct 2008
    On Earth
    340 USD + shipping cost to my country 90 USD + 24% VAT in my country.
    Come one guys... I recived few PM's about that.
    I so sorry that I made a joke but I supposed that here in DK are smart guys.
    Thank you and sorry for the one of us who dosen't recognize a joke.
    Good luck
    P.S. What do you think thay will do ? Do you think that they will sell you the dump to make a clone a genuine one?
  2. #347
    OK
    We recognize a joke
  3. #348
    Newbie ThePohorc's Avatar
    First of all: thanks all of you for the useful tips till now. I have a Chinese clone (FT232BL) and yesterday I started upgrade to 908 version (from 805.0).
    All went well. I removed SCT chip, transistor and resistor, flashed MCU with new flash and EEPROM (Arash) and at the end I changed flash on FTDI. All went well according to plan (and tutorials)
    Now, when I install VAG-COM 908.0 it says: Error, cable not found.
    When I test the same cable on 805.0, it works well. If I check FW version (on 805.0) it says: 1.81, so, the upgrade went well. The same problem appears on 10.6.0 Software...
    What could be wrong?
  4. #349
    You have Error during instaling vcds908 ?
    - or when
    you start installed program ?
  5. #350
    Nop,
    No Errors. Just wont work...
  6. #351
    Portugal
    Quote Originally Posted by hevi View Post
    Just to keep in touch...
    First i removed the STC chip and pluged to car...cable recon as serial...uninstalled and installed driver and cable recon as ross...still shareware.
    Then reprogramed again FT232BL and cable now is not recon in Windows XP.
    Will try to reprogram atmega and tell you result later...
    Just doing this steps to se results...
    Thank you again
    edit: do i need at the end flash 1.83 or can i stay at 1.81 for 905
    ok finally had time to flash atmega.
    After that cable was ativated...but...if i desconect it and connect again laptpo says device not recon...but if i connect cable to another laptop that did not connect to car it is recon as ross.
    Everytime i conect and disconect from car laptop loses driver info and cable info.
    format and install xp and all ok for one use again, same problem after disconect.
    Each time i disconnect cable from laptop have to format and install xp.
    any suggestions for this?
  7. #352
    xoom's Avatar
    Ylakiai
    first you need to flash atmega with good dumps.. then ft232.. and then it should work.. it cannot be that need to format disk and reinstall windows
  8. #353
    Portugal
    ok will try that because i was first prog. ftd then atmega.
  9. #354
    xoom's Avatar
    Ylakiai
    actualy it's not so important.. but looks like you have bad dumps.. if dump are ok then ft2332 eeprom is not destroyed..
  10. #355
    Portugal
    the problem is just when i disconect cable from car/laptop.
    if i connect it again gives device not recon, but if i connect that same "bad"cable to another laptop it is recon as ross.
    the first laptop just recon cable after format and install windows xp.
    strange isnt it?
    Dump i use is from here
  11. #356
    angelx431's Avatar
    Sep 2010
    BG Sofia Madrid
    Could someone make one video of programing of vagcom atmega162 and ftdi???
  12. #357
    Portugal
    Quote Originally Posted by xoom View Post
    Any chances of you send me good dumps?
    Thank you in advance.
  13. #358
    Oct 2008
    On Earth
    For what version?
    908?
    Good luck
  14. #359
    strange isnt it?
    DONT INSTAL WINDOWS XP,after lost device ,just try remove drivers from C: (Attachments) and connect interface.
  15. #360
    angelx431's Avatar
    Sep 2010
    BG Sofia Madrid
    Quote Originally Posted by mattydr67 View Post
    For what version?
    908?
    Good luck
    311.2-Vietnamese!!!!!!!!! Vietnamese
