Page 244 of 854 FirstFirst ... 144194234239240241242243244245246247248249254294344744 ... LastLast
Results 3,646 to 3,660 of 12803
  1. #3646
    Friends I have maybe a dumb question. I know that maybe many of us have got a bad VagCom/VCDS interface and the main reason of this thread is to safe/reprogram/reflash it taking to live again, but my question is, as many interfaces today are very similar, which other uses/firmware/software this cable can be moded to work as? Something like the CANtieCar interface.
  2. #3647
    ATMEGA in external programmer - file dump.bin
    FTDI - ept file via MPROG
    93** - via serial programmer
    Which file should I use for GAL ?
    I mean version 11.11.0 from this thread.
    I have got RL version.
  3. #3648
    "FTDI - ept file via MPROG
    93** - via serial programmer"
    If you have RL version you don't need "93Cx6" dump.
    Gal dump if you'll search, you'll find. Here...
    B.e. http://www.digital-kaos.co.uk/forums..._smartprog.rar
  4. #3649
    B.e. www.digital-kaos.co.uk/forums/attachments/f152/39587d1290251100-vag-com-vcds-everything-atf16v8_smartprog.rar
    Mprog can not write the eeprom 93c **?
    only through a programmer?
  5. #3650
    Oct 2008
    On Earth
    Quote Originally Posted by spider-wifi View Post
    Mate the 93Cxx it is there th eeprom of FTDI FT232BL/BM
    You can flash in this case by USB using MProg
    But also you can flash the eeprom 93Cxx using an external programmer ( for example using PonyProg )
    You got it now
    Good luck
  6. #3651
    Thanks for the explanation, I also thought
  7. #3652
    Someone dump for ATMEGA162 the Czech version?
    10.6.4 and newer?
    I do not want it free
    thx
  8. #3653
    Feb 2013
    Can you tell me from that picture , for flashing the atmega chip .. witch are Mosi - Rst - Sck -MisO ... so i could solder them with som wires...
    Thank you very much .
  9. #3654
    Quote Originally Posted by bounce24 View Post
    check page 227 for it
    http://www.digital-kaos.co.uk/forums...ml#post1760300
  10. #3655
    Oct 2010
    Hello gentlemen!
    Question - will VCDS work with VASPC bluetooth head?
  11. #3656
    Oct 2008
    On Earth
    Quote Originally Posted by mosrespect View Post
    Hello gentlemen!
    Of course not
    Good luck
  12. #3657
    This dump is over ... Can anyone break it down into Flash and EEPROM??? If my cable is 93c56, can be used for this 93c46???
  13. #3658
    DK Veteran bibkare's Avatar
    B & H
    it doesn't matter which type of external eprom ftdi use ...c46 or c56, you can use it on both of them, difference is in ftdi chip bl or rl, becase you can't use same eeprom template on both chips
  14. #3659
    Who can split it into Flash and EEPROM???
  15. #3660
    RF
    Quote Originally Posted by dani_94 View Post
    WinHEX or other binary viewer.
    address: 00000000...00003FFF - flash
    address: 00004000... 000041FF - eeprom
