Page 249 of 854 FirstFirst ... 149199239244245246247248249250251252253254259299349749 ... LastLast
Results 3,721 to 3,735 of 12803
  1. #3721
    Mar 2013
    vcds schematic or pcb please send me
  2. #3722
    Harrycz44
    Guest
    Hello all DK friends, I have problem with my vcds. I use 10.6.1. When I tested without car ( no-power ) Show port: OK, interface: Hex- found, type: Ross tech...., no connect to car. But when I connect interface to car test show: Port OK, Interface HEX: dont found! wrong driver.. Pleas help. Thank you
  3. #3723
    Unpowered: go to device manager; you'll see VID and PID for cable.
    Power up, test; the VID and PID are the same? If yes, try to uninstall ALL VCDS and ALL VCDS drivers, from control panel, from registry and using too FTClean for FA20 and FA24. Restart, reinstall 10.6.1 and try again, eventualy with installing driver manualy.
    If VID PID are not the same, wrong eeprom dump, 93Cx6 faulty, FTDI faulty or..STC try to write in FTDI/93Cx6 another VID/PID...
  4. #3724
    Harrycz44
    Guest
    Hello I try change PID for 20 and 23 and some problem driver correct load, but when is cable under voltage test is wrong.
  5. #3725
    I don't understand what you say.
    Post here "print screens" with VID and PID unpowered and powered interface.
    And two photos at good resolution with both sides of PCB.
  6. #3726
    Hi everyone!
    I repaired a couple of VCDS cables in the past mostly cablwes up to VCDS805, but today I got a vcds 908 RL version, It has ben updated via internet so now not working.
    As I read about 50 pages of this topis I understand it is a FT232RL the most difficult one to repair
    here's a picture of PCB:
    now my questions
    If I follow this aminebot tutorial :
    - Reflash Atmega with 908 dump 908.rar.
    - Remove components IC8 , R50 , R51 , D7 as shown on the pic with red arrows.
    - Re-flash FTDI with this dump.
    - Re-flash GAL16V8 (ATF16V8) with this dump.
    - Solder 3 wires as shown on the pic with blue lines.
    - Extract files in this archive to your VCDS directory.
    Is there a new method?
    What tool do i need to reprogram GAL ?
    or can I try this method ? remove the gal :
    Thanks in advance for help!!!!
  7. #3727
    Oct 2008
    On Earth
    Mate
    Aminebot solution it is the best
    The other solutions ( without GAL ) it is good too
    But as we know it is not good enough. Some functions will not work. But as I said you can do it because it is much easy to do it
    What I didn;t understand it is why in one pics this solutions whithout GAL it was done in a FT232BL tool?
    There's no need to remove GAL to to reflash it.
    Good luck
  8. #3728
    Because GAL, sometime can broken too; but..the solution is not the best.
    GAL have a function, if not, RossTech would be removed.
  9. #3729
    So are you saying that I can flash GAL (JED file) without removing it from the PCB? How?
  10. #3730
    Oct 2008
    On Earth
    Mate you didn't understood
    If you have a tool with FTDi BL or BM you don't need to remove the GAL and don't need to reflash it
    If you have a RL tool of course you need to remove it and the reflash it. You cannot flash it on PCB
    Good luck
  11. #3731
    Thanks, it is all clear to me now
  12. #3732
    Apr 2013
    Can I find somewhere dumps for firmware 1.92?
    Thanks!
  13. #3733
    You can find this firmware in this thread, but without eeprom it will not work.
  14. #3734
    DK Veteran mishu_b's Avatar
    Land of Choice!
    Quote Originally Posted by mattydr67 View Post
    Good luck
    partiality true -
    if you have an old tool up to 908 and than update to 11.x.x for correct working in all functions GAL/ATF needs to be mod accordingly.
  15. #3735
    Apr 2013
    how to get a dump tp 11/11 vcds?
