Page 250 of 854 FirstFirst ... 150200240245246247248249250251252253254255260300350750 ... LastLast
Results 3,736 to 3,750 of 12803
  1. #3736
    Quote Originally Posted by mishu_b View Post
    partiality true -
    if you have an old tool up to 908 and than update to 11.x.x for correct working in all functions GAL/ATF needs to be mod accordingly.
    Can you be more explicit, please?
  2. #3737
    partiality true -
    Yes, please explain what has to be done. I want to upgrade 704.1 cable to newer 11.11 version.
  3. #3738
    Jan 2013
    Im using a vcds 10.6.2 can we do something to upgrade it to 11.11 ?
  4. #3739
    Feb 2013
    I want to reflash FTDI (RL) with dumps for vag 10.6.2 but no look to find this dumps.
    No free dumps for (FTDI) 10.6.2?
    Can I use (ept) dump from 9.0.8 to reflash FTDI from a cable that uses 10.6.2 ?
  5. #3740
    Oct 2008
    On Earth
    FTDi it is the same
    You need to change the Atmega dump if you want to reflash or to upgrade/downgrade the version of VCDS
    Don't make confusion
    Good luck
    P.S. The dumpr for FTDi it is the same in 908 and in the 10.6.2
    All you need it is to find an Atmega dump for the version you need to reflash
  6. The Following User Says Thank You to mattydr67 For This Useful Post:
    alexm1 (12th April, 2013)
  7. #3741
    Feb 2013
    For the start I will try reflash only the FTDI, maybe Atmega is ok.... if it is not ok, I will not try to reflash Atmega, because FTDI is RL and GAL must be removed... and so on.
    But EPT for RL will work with BM/BL ?
  8. #3742
    Oct 2008
    On Earth
    No there are diffrent ept for BL/BM and RL
    You can try like this first reflash the FTDI
    If it will work you are a lucky guy
    If not...
    Good luck
  9. The Following User Says Thank You to mattydr67 For This Useful Post:
  10. #3743
    Feb 2013
    I will do that, first I must search EPT for RL, I hope I will find it "here" in this thread.
    Thank you!!!!!
  11. #3744
    Oct 2008
    On Earth
    Here it is
    Good luck
    FT232RL.rar
  12. The Following 3 Users Say Thank You to mattydr67 For This Useful Post:
    alexm1 (12th April, 2013), cheaper (31st May, 2013), faza83 (25th June, 2013)
  13. #3745
    Feb 2013
    Thanks again... I will bring news after reflash.
  14. #3746
    Fec001's Avatar
    Hi!
    I need some help. When I try to connect to any control unit in vcds, the program freezes and after som time write Too many communication errors to continue! When I get the cable everything works perfect but after some time all get wrong. Tried with 10.6.4, problem is the same...
    Thank you!
    FT232BL MCU and 93c56
  15. #3747
    Oct 2008
    On Earth
    Mate
    First of all unistall your softwears. Erase the rigistry ( you can use a CCcleaner for this )
    then reboot the OS
    After this install the VCDS softear back
    And Test it in a car
    Please teaka look after this into the ABOUT and you'll see if the tool it is still activated/registred
    If itsn't then you'll know what to do next. Maybe you need to reflash the tool.
    Good luck
  16. #3748
    Fec001's Avatar
    I tried with other laptop what has fresh xp and problem is the same. Tried reprogramm eeprom with external programmer and tried to reprogram with Mprog
  17. #3749
    Oct 2008
    On Earth
    Mate
    If you have an unregistred/unactivated message then for sure your tool it is erased.
    So all you have to do is to reflash the Atmega and the FTDI ( if this need ) and then install a fresh Windows and VCDS softwear.
    After this DO NOT CONNECT this computer TO THE INTERNET....EVER
    Or you'll reflash your tool allways.
    Good luck
    P.S. there's also solution to not flash your tool anymore, well just if you want to upgrade it.
  18. #3750
    Fec001's Avatar
    I get registered
