Page 254 of 854 FirstFirst ... 154204244249250251252253254255256257258259264304354754 ... LastLast
Results 3,796 to 3,810 of 12803
  1. #3796
    Mar 2013
    Warsaw
    Quote Originally Posted by ovix View Post
    Attachment 195434Attachment 195435
    This is the interface. (VG.A 2010-04-08)
    I made an Interface Test, and the result was K1-OK and K2-OK.
    How to reflash Atmega on this board?
    Is it enough to solder the SPI for Atmega?
  2. #3797
    Oct 2008
    On Earth
    Yes and power it up with 12V
    Good luck
  3. #3798
    Jan 2013
    Hello.Is there a guide in PDF how to update my VCDS 10.6 Cable to VCDS11.11 ?
    What should i check ?
  4. #3799
    Feb 2012
    Poland Konin
    Default VCDS 10.6.3 i 10.6.5 i 11.3 beta
    instructions to upgrade to 11.11 but do not have the Poles who are looking for the installer loads, drivers, and user insnstalacji I put RAR.
  5. The Following 3 Users Say Thank You to telesfor For This Useful Post:
    dersven (14th August, 2013), eliah (16th January, 2016), faza83 (25th June, 2013)
  6. #3800
    Default vcds11.11 full dump&installer
    I use parallel programmmer with 4 resistor, and work perfect....
  7. The Following 2 Users Say Thank You to LPSERV For This Useful Post:
    eliah (6th November, 2017), kleanthis sti (5th July, 2019)
  8. #3801
    Aug 2011
    if i teoreticaly have had a few dumps from org cabel with ft232RQ chip, is there a posibility to transfere that eeprom to cable with ft232BM cable and get it working? as even serial that depends on ft type is not correct and license will not pass without modification many thanks
  9. #3802
    Jan 2013
    Quote Originally Posted by telesfor View Post
    U have something in English ?
  10. #3803
    Sep 2012
    Please can someone help we with this!!! been trying to fine out if chinese clone cable 11.11.3 will work with the hex mp9 reset software...
    i have been looking everywhere to see if anyone has tested this. thanks
  11. #3804
    I have the 11.11.3 for ft232rl based interface without gal.
  12. #3805
    Jun 2012
    Helo mates,
    I have one little question from where can I take working clone to update it to vcds the newest version. Would it be an good to buy it on ebay but what I should to write on the search field to get really working one or the best idea will be made one by myself. Could You give me some liks.
    Which interface will be better:
    http://www.ebay.pl/itm/LATEST-VAG-CO...item4610074e4d
    or
    http://www.ebay.com/itm/181155039749...ae8a05&vxp=mtr
    Thanks in advance for the answer
  13. #3806
    Oct 2008
    On Earth
    Mate
    Akk this new chinese tools working with 11.11.3 or with 12.10.3 beta are the one without GAL/ATF
    So first of all it hasn't GAL/ATF and this is bad, no all functions activated.
    Then the Chinese softwears are made to "kill" your tool not to protrect becasue they need to sell more not to make you happy.
    The protection with firewall or to write 127.0...... into the HOSTS it is not a good solution for now.
    So if want to have no problem in the fuhure you need to spend more money the 20-30 USD and you'll have a HQ clone and no internet problems at all.
    But this you'll not find in the ebay for sure
    Good luck
  14. #3807
    RF
    Quote Originally Posted by andrius View Post
    I write a loader in such cases . And the program starts working with it eeprom.
  15. The Following User Says Thank You to magadan For This Useful Post:
    liviudiaconu (12th June, 2013)
  16. #3808
    Jun 2012
    Thank You mattydr67 for Your fast answer but where I could buy this clone. Do You recomend some solution or web shop
  17. #3809
    Oct 2008
    On Earth
    Sorry mate
    I cannot help you in this, I mean to recomand someoneelse or a web shop.
    Good luck
  18. #3810
    Feb 2013
    1.JPGDSCF1198.JPGDSCF1201.JPGIt is necessary , before reflahs, to remove some parts from this interface?
    It is FTDI-BL and from what I read on the forum must stay how it is...
    I am asking because I reflash it with 11.11 and after first autoscan became "unregistered".
