Page 255 of 854 FirstFirst ... 155205245250251252253254255256257258259260265305355755 ... LastLast
Results 3,811 to 3,825 of 12803
  1. #3811
    Oct 2008
    On Earth
    Yes of course you need to unsolder the Q9 and R51 must be there another component but I canno t see it. I suppose that it is near the USB wires ( it is Tx )
    After you'll unsolder this component, you have to check if there's any short cuts and if there isn't any you can reflash it
    Good luck
  2. The Following User Says Thank You to mattydr67 For This Useful Post:
    alexm1 (13th June, 2013)
  3. #3812
    Feb 2013
    I found R51 it is next to LED, but Q9 wich is it? And the third component?See new and more clear photo, if you have some free time, please edit one of the photo and indicate what to unsolder. ok1.JPGok2.JPG
  4. #3813
    Oct 2008
    On Earth
    Yes unsolder U9 and r51 then flash the Atmega
    Good luck
  5. The Following User Says Thank You to mattydr67 For This Useful Post:
  6. #3814
    Feb 2013
    I did what you said and after few scans it is Fully Registered.
    Thank you.
  7. The Following User Says Thank You to alexm1 For This Useful Post:
    ni88l3r (8th January, 2017)
  8. #3815
    Jun 2013
    Hello everyone, I have my block pcb after an update, today I read a lot of pages and I can not find pcb identical to mine and I do not know what I must here are photos he was in English 10.6.4
    if a charitable soul to help me thank you20130615_193012.jpg20130615_193045.jpg20130615_193217.jpg20130615_193221.jpg
  9. #3816
    Oct 2008
    On Earth
    Flash the Atmega thats all
    Or unsolder the STC if you don't let you flash
    Good luck
  10. #3817
    Jun 2013
    issue after the flash, it must return the STC because I wanted to flash the FTDI but nothing to do, nothing happens thank you
    question about the copy or original interface??
  11. #3818
    Quote Originally Posted by spider45 View Post
    Is your's pcb photo? If yes, must work without STC
  12. #3819
    Jun 2013
    Hello there I am with pictures of the PCB with jtag house that can remain inside20130617_152113.jpg20130617_152529.jpg
  13. #3820
    RF
    It is possible to tear off connections to a chip atmega if often to use 4 pin connector. It will be so better as I consider.
  14. #3821
    cniky's Avatar
    12.10.3 ENG - China , dump included, enjoy !
    pass - digital-kaos
  15. The Following 11 Users Say Thank You to cniky For This Useful Post:
    alexm1 (25th June, 2013), angmar (20th November, 2015), damndrunk (6th July, 2013), dantetimoc (1st July, 2013), eliah (6th November, 2017), Ginocar (6th September, 2013), ilico (25th January, 2016), mdanilo (24th June, 2013), s2000 (20th April, 2015), t1tan1 (4th December, 2013), youssef70 (25th September, 2013)
  16. #3822
    Nov 2012
    poland
    Rar indicates an incorrect password
  17. #3823
    Pass is correct.
    It should work with RL tool? And what VID PID should it have?
    I have tried FA24 and FA30 and it doesn't want to find interface.
    And why serial in dump and in VCDS is other
    Serial in dump:
    hexc715-00A8F2-A9D716-.....
    Serial in VCDS:
    hexa193-00c66e-3ee7a9-.....
  18. #3824
    Realy working?
  19. #3825
    With RL tool and FA24 doesn't work, doesn't want to pass TEST in options. I haven't tried FA30.
    If serials are different I think it's fake.
