In rt-usb.inf file have only fa20,23,24,25, so...fa30 don't work...
Nice idea!
Will not work with BM/BL?
Nop
Good luck
Rar indicates an incorrect password please
I have now VCDS 912 RL clone, which dump can I load into and what version can I use without modification of GAL (I have removed D7, IC8, R50,R51), 10.6.4/11.2? With loader I think?
I have tried 11.11.0 and 11.2 with loaders and when I make TEST it shows message about not found interface or not plugged in car. Fuses wa CD DC F9 C8 at first, now they are CD DC F9 FF. FTDI RL was set to FA24 with RT000001.
You must reprogramm gal and reroute (solder 3 wires).
Like in Aminebot's tutorial. And, of course, use a specific loader for every version you use.
Or, choose the solution "without gal" but...i understud that you cannot make all programming and adaptation with VCDS...
I have not a programmer for GAL, without GAL all functions on K-line will work?
GAL is for K-line functions..
hello all are what someone would flash the recent french? thank you
or the latest available version
GAL is only for dumb interface mode, to work as pass through as simple kklso without GAL all VCDS functions not requaring pass through work, as Atmega takes all calculations for k line and CAN using VCDS. will repeat GAL only for dumb mode
they do not hide it in official page
is there a way to bypass security for RL chip, for eg if i have an org cable with RQ chip and have full content of Atmega, how can i get it working with simple BM type adaprets, as for not it shows license in red, as ican not find a way to write license to RL chipsanyone could help?
maybe for a small reward
PM please
Your EEPROM atmega the bad.
1. The loader (vcds.exe) wants ChipID=$7A5E for FT232R. And eeprom atmega has ChipID=$7F17 for FT232R.
2. But even if to change ChipID to the necessary value, all the same a cable isn't tested.
This eeprom or is incorrectly calculated, or from other language version of the program.
1 6 D (1st July, 2013), JetSet59 (23rd July, 2013), liviudiaconu (28th June, 2013), paro44 (28th June, 2013), spider45 (28th June, 2013)
