Page 258 of 854 FirstFirst ... 158208248253254255256257258259260261262263268308358758 ... LastLast
Results 3,856 to 3,870 of 12803
  1. #3856
    DK Veteran bibkare's Avatar
    B & H
    Quote Originally Posted by bounce24 View Post
    Hello ,
    I have a vag 11.11.3 clone it is with FTDI 232 RL chip... and i try to resoft it , i used some programmer to resoft the ATmega 162 and it works to resoft , but the LED is not flashing at all and the interface doesn't work. It has no GAL chip . So please can you help me ? i will attach some picture with my interface ?Attachment 209155Attachment 209156
    Hmm, i've seen a lot of interfaces like this one lately. Unfortunately they are total c.r.a.p. First you need to check voltage regulator 7805 and if it's OK you will have to reflash atmega again with another dump (probably special chinese dump) because LED is controlled by atmega. Honestly i think it's a waist of time, get another interface based on ft232bl.
  2. The Following User Says Thank You to bibkare For This Useful Post:
    perotok (14th July, 2013)
  3. #3857
    What regulator? That interface haven't voltage regulator, all 5V are from USB.
  4. The Following User Says Thank You to liviudiaconu For This Useful Post:
    bibkare (16th July, 2013)
  5. #3858
    Feb 2013
    hi , and thanks for advice ...but like "liviudiaconu" said it has no 7805 regulator . So do you have some other advice ? thanks in advanced .
  6. #3859
    Plug to +12V, plug usb cable, make sure programmer GND is connected to interface GND, programm Atmega with proper dump.
    Make sure you have VID 0403 PID Fa24.
    Use proper soft.
    At the end of programming atmega the led must start lighting, first red after green.
  7. #3860
    B & H
    Thanks liviudiaconu you're right it doesn't have, i was speaking without thinking, force of habit i guess "if LED doesn't work automatically check 7805". Funny tough i have one interface like that here on my table and i soldered 7805 on it maybe that's what confused me. Anyway sorry for distraction.
  8. #3861
    Feb 2013
    ok thanks for this advice . Actually I used the 11.11.0 dump ...maybe this is the problem . I think the the + 12 V and GND i put ok . Do you know where i can find the 11.11.3 dump ? can you send me a link ? Thank You very much !
  9. #3862
    Quote Originally Posted by bibkare View Post
    [...] i soldered 7805 on it maybe that's what confused me. Anyway sorry for distraction.
    If you solder 7805 you must cut a "copper track" or "copper line" between +5V USB and +5V Atmega and other. If you think logical, you'll find.
  10. #3863
    Jun 2013
    hello friends I have to recover a multilengage PCB, it runs in french with latest version 11.11.5 11.11.6 and in English.
    that PCBs are a team atmel chip 162 gal 16V8 and FT232RL mcp 2515
    my question would be recovered dumps for this PCB to dump
    is there a risk to the pcb and how to thank you20130717_063250.jpg20130717_063544.jpg
  11. #3864
    The interface don't work? Is recognized as VID 0403 PID FA24?
    If Yes, must reflash atmega with proper dump and use proper soft.
  12. #3865
    B & H
    I did it just for testing, without plug in USB cable into PC. This interface is for spare parts, it has 1AM transistors which are better than J3Y
  13. #3866
    Mar 2011
    i recieve VCDS clone 12.10.3, i installed software but when i go to device manager to select driver from folder where i installed VCDS software, there no driver is found, what should i do?
  14. #3867
    Mar 2011
  15. #3868
    Mar 2011
    Quote Originally Posted by magadan View Post
    Atmega is under a glue, it is right for 99%. You remove glue on the left side of a chip (look figure 2 and 3). When you will see contacts, check connections:
    pin1(Atmega) - pin14(MCP2515)
    pin2(Atmega) - pin15(MCP2515)
    pin3(Atmega) - pin13(MCP2515).
    The reference mark is the left top corner of a chip. Counting is conducted counterclockwise. If these connections are present, it atmega. Connect contacts with a programmator so:
    pin13(MCP2515) - SCK
    pin14(MCP2515) - MOSI
    pin15(MCP2515) - MISO
    pin4(Atmega) - Reset
    Contacts of GND and +5 volts (if it is necessary) attach to L7805CV.
    G T R V is contacts for IC8 programming (chip-protect) look figure 1.
    Here it is your connections:
    is this programmer OK to do this job?
    PIC K150 ICSP Programmer USB Automatic Programming Develop Microcontroller + USB ICSP cable-in Other Electronic Components from Electronic Components & Supplies on Aliexpress.com
  16. The Following User Says Thank You to ludbe For This Useful Post:
    rudamie (27th July, 2013)
  17. #3869
    Oct 2008
    On Earth
    Mates my advise is that when you want to spend money ( chep price especially ) on a chip cracp tool be carfull
    That tool without GAL can works just with its softwear and I suppose that it was shared in this thread or in other one ( I don't know which one ) the dump for VCDS 12.10.3 which ( the psoter said ) it works with this kind of tools
    I suppose that dumps we all all and all the other that just one of us know item dose't works with this tool
    So when you buy a new tool be sure that this one it has Atmega ( first of all - if it has NEC do not buy it ) then be sure f it has GAL ( very important to be able to use all the functions that VCDS has ) and in the last take care to be with FTDI BL/BM ( if it has FTDI RL it is not such a problem abut take care that it has Atnega + GAL +FTDI )
    Then you cna buy it
    And the most important think when you buy a chinese clone it is that before you install the softwear do not have any internet connection and after installation of VCDS remove forever your internet connection.\This is if you like to have a good working tool in the futhure. Otherwise the tool it will be erased if you have any internet connection no matter when you use it
    Good luck
  18. The Following 3 Users Say Thank You to mattydr67 For This Useful Post:
    bibkare (19th July, 2013), ludbe (18th July, 2013), paro44 (18th July, 2013)
  19. #3870
    Mar 2011
    i have atmega + gal16v8b and ftdi is that ok clone? but anyway i must reflash atmega and i am asking u guys if this programmer will do this job PIC K150 ICSP Programmer USB Automatic Programming Develop Microcontroller + USB ICSP cable-in Other Electronic Components from Electronic Components & Supplies on Aliexpress.com
