Page 259 of 854 FirstFirst ... 159209249254255256257258259260261262263264269309359759 ... LastLast
Results 3,871 to 3,885 of 12803
  1. #3871
    Oct 2008
    On Earth
    Quote Originally Posted by ludbe View Post
    i have atmega + gal16v8b and ftdi is that ok clone? but anyway i must reflash atmega and i am asking u guys if this programmer will do this job PIC K150 ICSP Programmer USB Automatic Programming Develop Microcontroller + USB ICSP cable-in Other Electronic Components from Electronic Components & Supplies on Aliexpress.com
    Hi mate
    First of all that programmer it is forPIC MCU not for Atmega MCU
    Now take a look in the Device Manager and see what is the VID/PID
    if it is 0403/FA30 then you have to make some changes in the VCDS installed files of USB (in RT-USB.inf )
    So check this first
    Good luck
  2. The Following User Says Thank You to mattydr67 For This Useful Post:
    perotok (21st July, 2013)
  3. #3872
    Jul 2013
    RO
    Have someone a picture with the ATMEGA and wires. Where can I plug the interface to +12V on my computer ?
  4. #3873
    Oct 2008
    On Earth
    12V from an external power supply not from your computer mate
    Go on web and sear5ch about dattasheet of Atmega 162 and you'll see then the wires from programmer must go on first 4 pins of Atmega MCU ( 1,2,3,4 )
    Good luck
  5. #3874
    overs0ull's Avatar
    Nov 2012
    near the sea ... ;)
    Hi gays , i read the thread and is perfect .
    But please if someone of you can tell me something about my problem whit vag com 11.11.0 chines clone - the problem is it work fine all good , but when i start to see live data ot ecu , or abs don't meter . the vag com crash and stop communication or stuck for 10 sec. or 5 every time is different and i don't from what .
    I try whit different drivers , new fresh xp , and all usb ports - and is the same .
    Please if someone know the answer or what i suppose to do let say .
    Thanks for a help and Regards .
  6. #3875
    Oct 2008
    On Earth
    Mate
    First of all you ahve to see if your tool is it still registred or not\Then we will see if it is a hardwear issues or OS issue or computer issue or ECu issue
    So please uninstall your VCDS softwear, then reboot
    After this instl the VCDS softwear back and go to your car plug the interface to USB and to your car diagnostic connector and do a Tool TEST
    Then go to about and see if it is Registred or Unregistred
    Then please come back and tell us how it is and we will see then what\s your problem
    Good luck
  7. #3876
    overs0ull's Avatar
    Nov 2012
    near the sea ... ;)
    Hi mate , thanks a lot for the help . Tomorrow i will test and report after that cause the car is in not in me at the moment .
    I will make what you say and after that i will report .
    My Vag com 11.11.0 is chines and i think hi don't need registration but i will see .
    I will un install it , and after that go na install it again whit out to install or un install drivers - write , only the application VCDS 11.11.0 .
    Thanks for the help and Regards .
  8. #3877
    Mar 2011
    i have cable 12.10.3 version. With cable i get vcds 12.10.3 program without install.exe file but i must only copy and paste folder ROSS TECH to C: disk and create shortcut on desktop. I then connected cable to computer and tried to install drivers, but no drivers was found. That was on windows 7 32bit. The same thing i did on my windows xp, virtual machine, but there drivers was detected in ROSS TECH folder. I then installed them, but when i click test in vcds 12.10.3 program it says: PORT STATUS: ok, interface not found. Can someone help me? Regards
  9. #3878
    Oct 2008
    On Earth
    The led it is turned on?
    Plug it into the car and try TEST again
    Good luck
  10. #3879
    Mar 2011
    the led is burning green but no interface is found
  11. #3880
    Oct 2008
    On Earth
    Mate
    Plug the interface to the USB
    Go to Device Manager and check your VID/PID
    It must be one of this VID_0403/PID_FA20 if the tool it is with FTDI BL/BM or
    it has has to be VID_0403/PID_FA24 if it is with FTDI RL
    If you have VID_0403/PID_FA30 then you have to do some modification in RT-USB.inf file if you want that your tool to be recognized by the VCDS softwear
    If you have any other VID/PID then you need to reflash your Atmega
    If you have one of that VID/PID then go to your car and plug the tool to the USB and to the OBD connector to your car and TEST again
    Do this and lets see what will be next
    FYI two pics with your both sides of your PCB will be very usefull to see what kind of tool you have
    Good luck
  12. The Following 3 Users Say Thank You to mattydr67 For This Useful Post:
    apv (27th July, 2013), paro44 (26th July, 2013), tango5 (3rd August, 2013)
  13. #3881
    Mar 2011
    Hi guys I need HELP
    My vag work not, I will update Atmega 162 with Ponyprog with LPT solution
    MOSI: 1100 Ohm
    MISO: 470 Ohm
    CLOCK: 1100 Ohm
    RESET: 1100 Ohm
    Extrenal power
    Always I have troble code (-24)
    Hava you any Ideea ???
    Thankss
  14. #3882
    Why two values?
    Try ALL only 470 ohm
  15. #3883
    RF
    Quote Originally Posted by DiagService View Post
    Hi guys I need HELP
    MOSI: 1100 Ohm
    MISO: 470 Ohm
    CLOCK: 1100 Ohm
    RESET: 1100 Ohm
    Extrenal power
    Thankss
    Google will help you :" Ponyprog error 24". (The program doesn't see atmega.)
    1. Check connection atmega to the computer.
    2. Check settings of the interface in the program of Poniprog.
    3. Try to program atmega other programmator. (ISP-prog example).
    4. Atmega it can be closed for programming on this ISP-interface.
    And etc.
  16. The Following User Says Thank You to magadan For This Useful Post:
    liviudiaconu (29th July, 2013)
  17. #3884
    Mar 2011
    I have this version VID_0403/PID_FA24 , i tried today TEST several times but always same message here are pictures of PCB
  18. #3885
    Jul 2013
    I read somewhere that the system date had to be before may 20.
