I read,but not find![]()
results not found about 812.4
perotok (2nd September, 2013)
812.4 dump you don't find but you can find newer dump then yours and you'll be happy to have a new version of VCDS working with your tool
Good luck
Because that one it is a protection and if you'll not unsolder that components you'll not be able to flash the Atmega
You can also to upgrade to VCDS 11.11.0 as Mr. Magadan told you
Good luck
P.S. - if your tool it is identical with that one. It is not necessary to remove component in all kind of tools.
To be sure please share two pics of both sides of your PCB an dwe will tell you then what you need to unsolder or not
here photo
when atmega reflash,so IC8 solder back???
P.S 812.4 is china
Mate
Sorry I cannot open any of your archive ( even I'm using winrar and 7zip )
But the IC8 it is the STC
Do not solder it back any do not solder back any components that you allready unsoldered
Good luck
what version recommended for me cable?which is the best?
The last the best will said one of us
I advise to you to use VCDS 10.6.4
VCDS 11.11.0 has too many bugs in my opinion bun not such bad as other versions
Use the release versions not betas
Good luck
I have new problem,today received new vag-com 12.10 from china,and cable not working.
Mate
As i see you buying all that chinese sh..ts and you'll spend a lot of money on item and in the end you have no good working tool
That chinese tool must works if you change the computer date at least one day after VCDS softwear version releas.
Good luck
Yes,I change system date and all ok
