I can't open any archive from DK..
what is DK?
I have seen one problem with VCDS Beta 11.3. For a few days I read on some forums, that this version don't work if date is after 31 August 2013. I have seen at least 5-10 situations now.
All Betas version have a limit date
So 11.3 it is a Beta and it has that limit
I had in the past a version of VCDS 1.3 moded that works with 11.2 dump and has no date limit
But I'm very sure that I erase from my HDD long time ago
Good luck
Probably this moded 11.3 Beta have build-in runasdate which is set to back time for about 2 years.
No need this mate
Only you have to do it is to disable that date limit
You can disable aslo the message when a new version it is released
Good luck
or I can read atmega and eeprom from 12.10 cable,and write dumps to 812.4 cable? 812.4 updated up to 12.10?
Mate you need dump to flash Atmega but you cannot read it becasue it is protected
( I mean you cannot read it using a programmer )
Good luck
i read Thread but not found 10.6.4 version for atmega and eeprom![]()
Have all are you need!
What is the newest working solution for all RL tools without STC too?
11.11.0 dump with loader(plus GAL remove)? Or somebody have method to run this 12.10.3 dump:
http://www.digital-kaos.co.uk/forums...ml#post2010323
Maybe last 12.10.3 dump is only to repair 12.10.3 clones or for RL with STC only?
Strange thing is that nobody have decoded dump from 11.11.3 RL which doesn't have STC chip and have ATF, not GAL. I send to one person some sniffed data from it and still there is no news for about half year![]()
93Cxx can be flashed by external programmer or you can use ept file with MProg to flash the FTDI ( same thing )
GAL16V8 need to be flashed if you have a RL tool
Good luck
to me FT232BL so not need reprog GAL16V8??
maybe you have 93c46 bin file?
