Page 270 of 854 FirstFirst ... 170220260265266267268269270271272273274275280320370770 ... LastLast
Results 4,036 to 4,050 of 12803
  1. #4036
    RF
    Quote Originally Posted by 1 6 D View Post
    Friend have two VCDS clones, one for 11.11.3 and second for 11.11.4/12.10.3. Hardware looks identical, but dump for 12.10.3 doesn't work in this one for 11.11.3, serial in ABOUT is bit different and it's banned.
    Is it possible to check by multimeter which pins are connected by ATF16V8 when tool is working?
    Probably there is other connection because I have tested this dump in old 10.6.2 RL clone where I have removed GAL and use wires in his place, and serial is readen but banned.
    Write in more detail that you do. From where you took a firmware? And other.
    Your letter have double sense.
    Show photos of both cables. Load the software which you are going to use.
    You can write to me to PM.
  2. #4037
    mislav88's Avatar
    Mar 2011
    I have a problem with 12.10.3 beta.
    Only first value in measuring blocks is shown, others always show N/A. Where could be a problem?
  3. #4038
    Oct 2008
    On Earth
    In the softwear ofcourse
    VCDS 12.10.3 it is a betta version and also moded by chinese
    Good luck
  4. #4039
    Mar 2011
    Quote Originally Posted by mislav88 View Post
    have the same problem here
  5. #4040
    mislav88's Avatar
    Mar 2011
    Quote Originally Posted by mattydr67 View Post
    Good luck
    is it possible to use older sw with this hw?
  6. #4041
    Oct 2008
    On Earth
    You need to use dump for the sw version you wanna use. And as i know your tool it is a FTDi RL one base then for the softwera you'll need a Loader too
    Good luck
  7. #4042
    Mar 2013
    Warsaw
    My friend give me VCDS 11.11 with FT232BM.
    After connecting to PC it is visable in Device Manager as correct cable. But after some time (sometimes few minutes, soetimes few second) its disappears.
    When I reconecting cable its the same. I replaced the USB cable but no change.
    What you think, it is damage FT chip or bad soldering on PCB?
  8. #4043
    Oct 2008
    On Earth
    Can be bad soldering but 99% it is a bad FTDi chip.
    Change it and you'll have no problem
    ( I have this issues in many low quality cables but also in one or two HQ clone too )
    Good luck
    P.S. - this issue come in 99.99% of cases because you use the tool plugged to the car and USB and then you plug the power cable to the laptop because you have a low battery. My advise is in this cases to unplug the tool first then plug the power cable and after few seconds you can plug the tool back. But the better it is not using the tool in this condition.
  9. #4044
    DK Veteran bibkare's Avatar
    B & H
    Hi all,
    i discovered in my old stuff one piece of HEX-COM-CAN interface. When i tried it on, it was 1.36 firmware in it. I reprogrammed atmega with 11.11.0 dump and now it's not visible by any version starting from 704.1. Does anybody know what should be done to revive this interface because it has excellent hardware. (see pics) Thanks. I forgot to say that only version 409 could read firmware 1.84 but it's too old for any proper usage.
  10. #4045
    RF
    Quote Originally Posted by bibkare View Post
    ...I reprogrammed atmega with 11.11.0 dump and now it's not visible by any version starting from 704.1. Does anybody know what should be done to revive this interface because it has excellent hardware. (see pics)...
    1) The firmware(eeprom atmega) for com-port version of the adapter is necessary to you. The firmware 11.11.0 (on this thread) is calculated on usb-adapter version with FT232B chip.
    2) Or to delete MAX232 chip. To seal FT232B chip instead of it.
    3) Or write loader....
  11. The Following User Says Thank You to magadan For This Useful Post:
    bibkare (13th November, 2013)
  12. #4046
    B & H
    Thanks man, i figured that problem is related to firmware version, maybe i made mistake by programming eeprom, i should have done only flash and see what would happen. If i don't find valid dump i will try to connect ftdi with this.
  13. #4047
    I have now 12.10 clone tool, I have read it with USBasp. Is it big difference in fuses when it's CD DA F9 FC, when everybody say that it should be CD DC F9 CC/FF?
  14. #4048
    RF
    That's right. Such fuses stand on new cables from Ross. These a cable have a bootloader with large volume.
    Read datasheet on a chip atmega.
  15. The Following User Says Thank You to magadan For This Useful Post:
  16. #4049
    So in RL clones for 12.10.3 what fuses should I use? Now it's banned and serial is hexa193-00c66e-3ee7a9-...
    Fuses should stay CD DA F9 FC and I can program it with 12.10.3 dump with serial hexc715-00a8f2-a9d716-... ?
  17. #4050
    RF
    You have no new flash and a bootloader. Therefore you will use the old. Therefore fuses it is necessary to use the old. It everything is written in datasheets.
