password: xxxROSSTECH
Will change the date on each run
this item is garbage
What version of VCDS did you recive?
Good luck
xxxROSSTECH is pass for 12.12
mattydr67 (29th November, 2013)
i cant find anywhere that i need to supply 5V directly to the pcb - i did read somewhere to connect the USB to the PC during the flash and supply 12V to the PCB.
here is a link to the tutorial i am based on, it dosnt say anything about the 5V, are you sure about that? http://www.digital-kaos.co.uk/forums...50/index7.html post #95
You can supply 5v in this way or better is to supply 12v directlly in the obd connector ( pins 4-5 gnd and pin 16 as +12v )
In both of the cases the power supply gnd must be soldered togeter with the programmer gnd
Good luck
thank you for your reply.
i saw in few places to connect the usb cable to the pc and the external power supply's 12V+ to the most left leg of the 7805 and the middle leg to the GND of the external power supply and the GND of the programmer to the same GND. will it work?
one leg of 7805 it is for 12v in the middle it is GND and the other leg it is 5V
ofcourse you can
Good luck
You need to understand one thing and that is: Atmega is not powered via USB port, you have to power atmega either via programmer or external supply. From my experience it is safer to supply power from programmer than any other way because sometimes LM7805 can be unstable or doesn't supply pure 5 volts - depending on quality. Forget USB cable, it has nothing to do with atmega programming only for FTDI programming.
cocutanu (1st December, 2013)
I never got rewriting atmega without usb cable plugged into laptop
bibkare (2nd December, 2013)
As my frined mishu_b said you don't need to plugg it into the USB
Maybe you have other issues during the flashing but plugging the tool to the USB it has nothing to do with the Atmega
Good luck
is soo hard to plug the usb ...
if you get programming failed you will never be able to reprogram it
i have atmega doctor..
