Page 278 of 854 FirstFirst ... 178228268273274275276277278279280281282283288328378778 ... LastLast
Results 4,156 to 4,170 of 12803
  1. #4156
    hi
    Im read forum because have a message after programming
    bay interface china 12.10.3 make problem with 08 group block sea N/A N/A
    Port satatus OK Interface Found!
    Type: Ross-Tech HEX-USB
    version 1.81
    Status failed self test!
    K1 OK
    K2 OK
    no CAN work
    whats is problems
  2. #4157
    DK Veteran DjRomeoR's Avatar
    Nov 2011
    Garage...
    Hello, i have a problem and dont know were to write so sorry if my problem not for this topic.
    I have Passat B6 2005year EDC 16U34 and i know my pin code :18085.
    I tryed to login in 01 engine ,ore try put code in security access ,but to me came image and i can't do anythink :/
    Maybe some one know how long need wait for time will be expired? ore how to solve this problem?
    I put image of error.
    login,- security access.rar
    Sorry for my stupidity ,i turn on iginition on and wait 15min after what i enter 12233 , and all was good.
    Thx all for help.
  3. #4158
    So, to fix this 12.10 clone I have to change fuses to CD DC F9 FF and program it with this dump?
    Download 12.10.3.zip from Sendspace.com - send big files the easy wa
    post 4051
    this no working whith china clone end atf16v8b dump(no programing) is other RX TX pin n5 n13 old n9 n13
  4. #4159
    Member Pedro Poland's Avatar
    Does anyone have the files to version PL?
  5. #4160
    Last free polish version is 10.6.5 for BL/BM tools.
  6. #4161
    araby80's Avatar
    Jun 2013
    INSIDE ECU
    hello...
    i need help i have vag-com 12.10 and while i using it i forgot my internet connection open then i found unlicensed version error when i was reading sensor parameters !!!!
    help please how could i solve the problem????
    sorry for my bad English
    regards
  7. #4162
    Feb 2014
    Hi friends I want to buy a good chinnese working version of Vagcom that work ok on VW/audi/skoda.
    I'm looking on my chinese provider that exist a lots of versions 10.6, 11.11.1 ,12.10.3, 12.12.0 ??/
    Which of these work better, what you suggest me.
    Thx in advanced
    regards
    david
  8. #4163
    Jun 2012
    ALGeria
    i have vag commander8.6, i need the soft interne for my vag? whith mony i accept
  9. #4164
    Aug 2010
    Helo!
    I'm looking for 512 words bootloader. If someone has it please send me a private message. Maybe we can exchange some stuffs...
    The firmware it's not so important for me, I'm interested mainly in bootloader part of the dump (0x3C00-0x3FFF region of dump).
    The identification of bootloader version is easy. If you have a dump which need to following fuse/lock bits settings please send me private message:
    Low fuse: CD
    High fuse: DA !!!
    Extended fuse: F9
    Lock fuse: FF
    leader
  10. #4165
    Feb 2011
    Default New 12.12.0 clone with Nec chip
    hi everyone.I have a clone Vag 12.12 cable an it uses a Nec D79F8513A chip.(it was sent by mistake to me) since i ordered a different one. anyways -is this chip possible to reprogram or do anything with ?? also are there any data schematics for this chip in english ?? The cable runs fine for any Vag programs that use the Version 192 but doesn't work on older Version 184 Vag programs-earlier than the 11.xx Is this common on the newer cables,not like my 812.4 one. It has a "hexa193-00c6............." serial number. Thanks for any replies .................................................. .................................................. .................................................. .................................................. ............................. PS I found that the serial # is in the banned list in Vag 12.12.2. Have most of the dump of the eeprom area an found it needs a FT232RL chip,won't run in my older cable with FT232BM chip- RL chip has more memory an the program does some tests on it. Also,after unpacking Vag 12.12.2 you can see most serial # in plain text but alot are also encrypted in plain text ,so not seeing it doesn't mean its not on the banned list.
  11. #4166
    Apr 2014
    Hello
    My 11.11.3 cable had problems on k-line (was working for couple of seconds and then threw "too many communication errors"), while CAN on another car was doing preety good (I know there were some errors in communication as it had occasionally shown N/A value while measuring blocks). So I started to play with the cable and that is how I ended up in the state in which it does not work at all...
    Could anyone suggest a solution for such cable:
    imgur: the simple image sharer
    The FTDI is blank, no marks on it.
    thanks!
  12. #4167
    Feb 2013
    The same thing happened to me and the only solution is to reflash Atmega.
    L.E. your FTDI is FT232BL(or BM) .
  13. #4168
    Apr 2014
    Cheers, I know the solution is to reflash, but along with a reflash there are some additional procedures like dismounting/mounting other elements and/or programming other chips depending on the interface/pcb version.
  14. #4169
    Only reflash atmega with proper dump and, if necesary, FT232B
    But, you say "problems on K"
    With cable powered do a TEST (options->test)..
    K1 ?
    K2 ?
    CAN ?
  15. #4170
    Apr 2014
    I was like that until it broke:
    K1: OK
    K2: OK
    CAN: Not ready
    But it was on a 03 car that has K-Line and some kind of early CAN. The comuunication was killed with "too many communication errors to continue", but on a car with CAN communication was ok with small glitches (it was like occasional frame drops in communication, but the communication was not dropped itself)
    Now it is dead broken as I have been playing with it too much.
    So you say that I only have to program the atmega chip. I will try to do it and post the results.
    It's done, works great, no communication kills/drops.
