Conect today the car passes the test all OK!, REGISTERED / ACTIVATED but after the entry into SET, TEST ADAPTATION AUTOSCAN or pops up a message
To use this feature, you must have an original, professional interface with the license!
Contact us vagcom.Please help, or to program atmega or ft232bl.Thank you very much for help.
Hey Guys
I have read the thread but can't find what is wrong with my cable. My cable is the VAG 106, it was working with VCDS 10.6 but this morning i connected it and it came up with this message
"port status: OK
interface not found"
I have tried the method of disconnecting and restarting but it did not work
Try to connect and reconnect the interface for several times.
Fisrt in the OBD II plug and the in the USB then start the sw.
Sometime dosen't work.
The led is bicolor one and when you plug into the care is red, I suppose and when you plug into the USb and run the sw it must to chage the color in green.
Please check this.
I meant picture of interface inside, pcb both sides
That interface is based on 232RL and it work with Chinese VCDS 10.6 cracked softwear.
Good luck
For your kind of interface solution is here http://www.digital-kaos.co.uk/forums...ft232r-160237/
