Page 280 of 854 FirstFirst ... 180230270275276277278279280281282283284285290330380780 ... LastLast
Results 4,186 to 4,200 of 12803
  1. #4186
    Aug 2010
    Hello!
    Fuse settings not depends from the Interface version. It depends only from the type of firmware. The old public firmware has 256 word bootloader size where BOOTSZ0 is programmed and BOOTSZ1 is unporgramed. The newer firmware for FTDI RQ has 512 word bootloader size where BOOTSZ0 is unprogrammed and BOOTSZ1 is programmed. Any other fuse bits are the same.
    The screenshot about fuse settings posted by alexm1 is good for all public firmwares. All free/public firmwares (including the fw for 11.11.0 you posted in #4185) are old type firmware with 256word bootloader size.
    leader
  2. The Following 3 Users Say Thank You to leader79 For This Useful Post:
    alexm1 (10th June, 2014), humphrey (30th December, 2015), liviudiaconu (10th June, 2014)
  3. #4187
    Quote Originally Posted by leader79 View Post
    Hello!
    leader
    Thanks a lot ..............
  4. #4188
    Jan 2013
    Finland
    Hi, in Auto HVAC, is there a way to correct an offset between displayed temperature request and the actual cabin temperature? To get normal comfortable temp I have to dial in something like 16.5 - 17 degrees C which feels like 21 or 22C in reality. The car is Audi A3 8PA 2006, there are no fault codes in the HVAC system.
  5. #4189
    Feb 2013
    Quote Originally Posted by hezekiel View Post
    Hi, in Auto HVAC, is there a way to correct an offset between displayed temperature ....
    You will not find an answer in this thread, here we talk about how to fix/update vag com/ vcds cable.
  6. #4190
    I can't find eprom flash and config dumps for vcds atmega 162 use for xprog. Please help with dump 11.11 or any other english version, my interface ftdi RL type. Thanks
  7. #4191
    Aug 2010
    First use a the "Shearch thread" function above before asking. You can found it easy.
    The dump and loader for RL cable is shared many times, it's unnecessary to repost it on every 10 pages....
  8. #4192
    Yes I found many dumps for atmega, but xprog need config dump and flash eprom dump not like with ponyprog.
  9. #4193
    Mar 2013
    Can vcds read edc17 mileage ,if so what channel is used.
  10. #4194
    Aug 2011
    configuration bytes are simple, you may use them from any existing format or use HEX file, or just simply tic needed there are some in this thread too for EDC17, yes it may show km and much more just need correct channels, and logins and YES EDC17 has logins too...
  11. #4195
    cniky's Avatar
    Quote Originally Posted by DARFVADER View Post
    No, cannot , but you may check the DPF regeneration count and do yourself some math, you may find what you are looking for; DPF should not been deactivated and in good working condition, otherwise make no sense.
  12. #4196
    Jul 2014
    Hello fellow forumers of this educational thread!
    I have a perfectly working VAG COM 12.12 with the original release software.
    Now, the question is: Can I dump the micro with Xprog-M v5.50 without breaking it?
    Any ideas are appreciated.
    Thanks.
  13. #4197
    Firstly check if it there is ATMEGA or NEC.
  14. #4198
    Aug 2010
    Quote Originally Posted by AHANDY1 View Post
    Thanks.
    Hi!
    You can not read the content of ATMEGA with AVR programmer becaue is read protected.
    If you try to read it out than you will receiver dummy bytes instead of the real content.
    Of course there is at least 3 secret methods to read/rebuild the eeprom of the ATMEGA (the application area is not important) without AVR programmer but is not public (and I hope never will be public).
    leader
  15. #4199
    I bought a VCDS 12.12 clone and now it says it's not registered. I think the internet was on and it updated the firmware? Is there a fix for that?
    Thank you!
  16. #4200
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by brchip View Post
    Thank you!
    The fix is to buy another and make sure no internet next time
