Page 282 of 854 FirstFirst ... 182232272277278279280281282283284285286287292332382782 ... LastLast
Results 4,216 to 4,230 of 12803
  1. #4216
    Multipla's Avatar
    Turin,Italia
    Can you hel me, please? Can give me a ept of 409.1 hi lost a file of my cable and dont work. Please.
  2. #4217
    409.1 is a usb to serial converter..
  3. #4218
    Multipla's Avatar
    Turin,Italia
    Yes, but you have file bin or Hex ( ept) of this cable? Vag 409.1 please
  4. #4219
    I need ept file for KKL interface too.
  5. #4220
    Attachment 288955
    FT232BL? haven't memory, so no need ept, is by default 0403 6001.
    FT232RL?
    Mprog-> new ->...Device type = FT232R..save as..
    See in attach, are the files "by default" from FTDI.
    Every new FTDI 232 BM (without external memory) or 232Rx arrive with this parameters..VID 0403 PID 6001 =USB to Serial
    In yours cables must install driver from FTDI like serial adapter and made correlation between COM_y from interface with the same COM_y from (VCDSLite or VAG 409)->Options->PORT..
    Is recommended to choose COM1 to VAG and realocate COM1 for Serial converter.
    Device manager -> Ports-> COM_z (assigned to FTDI) -> Port settings -> Advanced-> port number...Com1 (can be in use..) ok-ok-ok...yess..etc to all questions..
    Like here:How To: Getting that eBay cable to work! - TDIClub Forums
    That if your device is with FT232.
    If not you need another driver:Attachment 288960
  6. The Following 6 Users Say Thank You to liviudiaconu For This Useful Post:
    clickerfux (22nd July, 2020), cocutanu (3rd December, 2014), Multipla (4th December, 2014), RogerioAndrade (3rd March, 2017), semga (10th June, 2016), titoun (18th December, 2015)
  7. #4221
    Multipla's Avatar
    Turin,Italia
    TKS all comunity in particular mode liviudiaconu.
  8. #4222
    Brest BY
    For your device must desolder IC8, D7, R50, R51.
    Reroute 3 wires and reprogramm Atmega, Gal, FTDI.
    Is named "Aminebot's tutorial".
    desolder IC8, D7 and reprogramm Atmega, FTDI...
    Hello everyone.
    I'm back...
  9. The Following User Says Thank You to andrey_brest For This Useful Post:
    liviudiaconu (19th December, 2014)
  10. #4223
    Top Poster zodiname's Avatar
    I have problem with 12.12 ,
    if I plug to usb and get port test then like foto 1 but if connect to 12v then like photo 2
    please help ?
  11. #4224
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by zodiname View Post
    please help ?
    I had this but installed a different 12.12 from the net and it worked
  12. #4225
    Can I reflash this (12.12 pcb photo) with old firmware1.810- 10.6 , 1.84 - 11.11 ?
  13. #4226
    Yes, is possible. Fw+Eeprom
  14. #4227
    how set lockibt and fusebits in upa to program atmega ?
  15. #4228
    Jan 2011
    Lithuania
    Hello DK,
    I have old VCds cable from China version 8.214 and something is wrong with it. If I connecting the cable to the car without CAN everything goes OK,but if I do connect to the car with CAN (example Touran 2004) program hangs on and after while I have a note: The cable not find... Does anybody know which chip refusing to work properly? Thank you
  16. #4229
    @pardul: try to read the fusebit and lockbits from atmega first... after write atmega with readed bits.
    @art64: do a test with interface only powered (connect only pin 16=+12V and 4-5 =GND).
    In in Option-Test appear K1-2=OK, CAN OK...can chips can be defective.
    If not...can be old version=>try rewrite with 11.11.0 dump and use VCDS 11.11.0
    My oppinion is the interface is erased or older version...
  17. The Following User Says Thank You to liviudiaconu For This Useful Post:
    art64 (4th January, 2015)
  18. #4230
    Jan 2011
    Lithuania
    If I do connect only
    pin 16=+12V and 4-5 =GND,everything goes OK - I wrote about it. And the CAN can't be OK in this case.( In this case: K1 -OK, K2-OK, CAN -not ready) But if I will do connect to the car equipped with the CAN , another message appears: "the Ros s tech cable did not find...." It can't be old version,because failure occurs suddenly a few years ago then I did connect to some one Audi. I bought a newest version 12.10,but the old version is better sometimes. The new cable do not ecu and immo swapping in immo 3 system. So I dream fix the older cable.
