Page 283 of 854 FirstFirst ... 183233273278279280281282283284285286287288293333383783 ... LastLast
Results 4,231 to 4,245 of 12803
  1. #4231
    roman_auto's Avatar
    Hi All
    I Jusy order Vcds version 12.12.1 with France language in mistake, can some one know what need to do, need it in English, do i need to download software or mode on the France one.
    If It Helped Push Thanks
  2. #4232
    Jan 2012
    Hello roman_auto,
    With VCDS chinese clone interface, you must only use the install executable that come with interface on CD-ROM.
    There is a risk to block the interface if you try an another install executable.
    My automotive tool :
    ? VCDS clone/copy interface but non-chinese
    compatible with last versions (v15.1.0, v14.10.0, v12.12.3, ...)
    and with free online updates for future versions.
  3. #4233
    Nov 2010
    Dear this is Chinese version and. U work with it and ur Internet was open so iin this case it will be damaged
    Or u try to update throw net this what I know
    Ihope if I can help u more
  4. #4234
    Top Poster zodiname's Avatar
    Reflash atmega for 12.12.0 english
  5. #4235
    roman_auto's Avatar
    Reflash, to read it with Upa and need to write some file to it , that what you mean
  6. #4236
    dimet's Avatar
    MKD
    Which is the best chinese clone version of vag com good working?
  7. #4237
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by dimet View Post
    Maybe pm mattydr67
  8. #4238
    RO
    Thanks guys for all informations posted here.
    Photos from my interface before and after removing the chip U9 (STC12C2052).
    Upgraded to 11.11 version, it's working.
  9. #4239
    who can help me for writting a loader?
  10. #4240
    Feb 2015
    after a long time reverse engineering, I found a solution for change a unregistered serial to a whitelist serial (activated).
    This Method works without a HW Programmer, wh opening the Interface, without any soldering.
    Updates works too :-)
    Maybe some Members suspect my Method...
    One little hint for you, it works via BL...
    I'm thinking on it to make it not open source. Reasons should be clearly...
    Maybe I'll share with few users here, if the had other interesting information for VCDS and other tools. Who did what, please PM.
    Sorry for my bad English, I'm not a natural speaker.
    DrWilly
  11. The Following 2 Users Say Thank You to DrWilly84 For This Useful Post:
    alin 151 (27th February, 2015), rideon (20th February, 2015)
  12. #4241
    antwnhszr's Avatar
    macedonia is greek....
    herllo all . today i find on my bench one cable from vagcom.it's vagcom 7094 but i don't work for any time.i reprogramm the atmega with dump for 11.11.0 vershion and the cable regognize the computer very well.i need litle help for someone guru on the vagcom cable because i open the cable and i see the some cable's inside is cut in....any one know how the connection from psb to obd2?.....i post some foto's here.
    regard's
  13. #4242
    You have the schematic and on your photo have 7, 15 of OBD and "XXX".
    Verify with an ohmmetter what pad is directly linked on that point, that pad must be pin 16 OBD.
    Look on the schematic and maybe you'll see more.
    LE>>.off, i don't know how to erase first photo, from edit windoww i erased but remain in little window..
    So, the good photo is with "7" line fragmented.
    LLE:
    K1 short to gnd can be reesistor between +12V bat and pin 6 of SY9241 interrupted or CI defective..
    Look on yours K Line CI, is possible to be another type...
  14. The Following User Says Thank You to liviudiaconu For This Useful Post:
    antwnhszr (20th February, 2015)
  15. #4243
    Mar 2013
    PH Romania
    someone cood help to reprogram my vcds,i HaVE VAG COM 11.11,and chip from pcb is Gal16V8,93c56,atmel ,mcp 2515,ftdi Ft23 dbl and TJA 1050.I need dump and ftdi zip files.And i need exact steps
  16. #4244
    Mar 2013
    PH Romania
    here i have 2 pictures with with my vcds
  17. #4245
    See pag 7.
    And "Search" function, is usefull.
