Page 284 of 854 FirstFirst ... 184234274279280281282283284285286287288289294334384784 ... LastLast
Results 4,246 to 4,260 of 12803
  1. #4246
    Feb 2015
    hello guys, i have a vag-com cable and i didnt use it for log time, now when i connect cable to car and computer need to update firmware, i click to update and then i got error, i cant update firmware what can i do to use it again ?
    thank you
  2. #4247
    VCDS cable CLONE work ONLY with the soft arrived with the cable. And the cable have inside the corresponding and necesary firmware.
    Any another version of soft can destroy your cable.
    IF your cable worked correctly with the soft arrived at the bought momment and now must update fw, you using a newer version (or by "curriosity" - "maybe work", or the pc has connected on internet at RT servers).
    In both cases try to uninstall all versions of VCDS having and drivers for vcds cable, including from registry, restarting pc and reinstall. Must know what you do.
    IF after that your cable work again, ok, if not, your cable must reprogramming.
    That's all is correctly for clones...
    For oem cable the update is free.
    Usefull is if you tell us more details: version, few photos from inside...FW version, etc.
  3. #4248
    Mar 2013
    PH Romania
    i search 2days.I cant find the exact procedure for my cable.I find the dump for my cable.I try to do with vidpidfix said no find dll. I just acomplished to write ftd232Bl,and atmega said no work to erase and write.
  4. #4249
    Mar 2013
    PH Romania
    here is tutorial
    Tutorial.pdf
  5. #4250
    Meat-Head's Avatar
    Quote Originally Posted by ionescudan View Post
    here is tutorial
    Tutorial.pdf
    Somebidy in this thread tweeted there are solder points in the board rather than direct to chip
  6. #4251
    GB
    I have a FT232BM.pid and vid are 0000/ how can return to the default settings 0304 and 6001?
  7. #4252
    use Mprog for ftdi
  8. #4253
    GB
    thanks but cant do this because wen i plug in the usb cable is tell to me unknow device. how do i fix this problem?
  9. #4254
    Feb 2013
    Read and folow next steps...( it is not my tutorial , it is shared somewhere over here on this thread..
    Step1: Please ensure that you have installed the VCDS software.
    Step2: Plug your disabled cable to the USB. There maybe be a pop-up window to indicate you to install the driver, for damaged cable, let it be, skip it.
    Step3: Right click "my computer", select " hardware", then "device manager", then "Other device", the " USB device".
    Step4: Right click "USB device", select "properties", select " detail", there will be a line information displayed. VID_xxxx & PID_xxxx, please write down the 4 letters or number for VID and PID.
    Step5: Unplug the cable, select" my computer" --"C:/"--"Ross-Tech"--"VCDS"--"RT-USB.inf".
    Step6: In item [FtdiHw], please add one more line as " %USB\VID_xxxx&PID_xxxx.DeviceDesc%=RT-USB, USB\VID_xxxx&PID_xxxx", (EXEMPLU:%USB\VID_0403&PID_6001.DeviceDesc%=RT-USB,USB\VID_0403&PID_6001)
    please ensure the four number or alphabets are the same as the ones you write down in step 4.
    Step7: In the end of the text, add one more line as " USB\VID_xxxx&PID_xxxx.DeviceDesc="VCDS Compatible USB Interface", the four numbers or alphabets are also the same as the ones you write down in step4.
    Step8: Save "RT-USB.inf" file and then exit.
    Step9: Unplug the cable, and then plug the cable to the USB port. System will indication found new hardware, and will pop up window for driver update. If do not have the pop up window, let it be, Right click "my computer", select " hardware", then "device manager", then "Other device", then right click "USB device", select update drive.
    Step10: Let the driver point to C:/Ross-Tech/VCDS
    Step11: System will search the drive for several seconds, then it will indicate that find the driver and then install it.
  10. The Following User Says Thank You to alexm1 For This Useful Post:
    iustin73 (10th March, 2015)
  11. #4255
    GB
    thanks alexm but il do all this thincs but nothing soon ill gonna got some screen capture to see and you.
  12. #4256
    Quote Originally Posted by iustin73 View Post
    Unknown device appear usualy when cannot communicate properly with FTDI. That mean interrupted cable or FT232 defective or locked.
  13. The Following User Says Thank You to liviudiaconu For This Useful Post:
    iustin73 (9th April, 2015)
  14. #4257
    Feb 2013
    A broken FT232BL from vcds cable can be replaced with FT232BM?
  15. #4258
    DK Veteran cocutanu's Avatar
    Jun 2009
    Quote Originally Posted by alexm1 View Post
    Sure. No problem.
  16. The Following User Says Thank You to cocutanu For This Useful Post:
    alexm1 (4th April, 2015)
  17. #4259
    laserkill's Avatar
    Default vcds 805.1
    Hello i have a china Vcds 805.1 i cant find the soft please can any one share with me. thanks and best regards.
  18. #4260
    Apr 2013
    Try this and report.
  19. The Following User Says Thank You to 2xded For This Useful Post:
    laserkill (8th April, 2015)
