Originally Posted by
liviudiaconu
At the same time two versions of VCDS is not ok. I don't think that working...
But, in the same session of windows i run let say, first 11.11.0, close, run 11.11.5, close..etc. I never restart windows for run the other version and never had problems. Not at the same time. Only one by one...
The problem can be if have 11.11.0 and 11.11.x, X>=1, because 11.11.0 use a bad version of driver. Try uninstall driver for 11.11.0 (2.08) and reinstall from the folder of vcds (newer version) or (older that 10.6.4)...
But, at this time, except the named "HQclone" for none of the rest of versions use internet. Is possible that RT find the sollution for "bypass" the protection made by "hosts" or by loader and....
My recomandation for using internet is: disable internet connections all.
Run VCDS from an external disk (USB stik, external HDD, sdcard..etc)..
After, remove external disk and reenable internet.
Is a good solution, but for clones the better solution still remain "on diagnose pc, not internet connection, all network cards disabled". That because of "history" of protection..was protection with STC, was broken..etc..
Is only my oppinion...
