Page 288 of 854 FirstFirst ... 188238278283284285286287288289290291292293298338388788 ... LastLast
Results 4,306 to 4,320 of 12803
  1. #4306
    pin 25 of lpt cable is soldered to gnd of vcds cable?
    eventualy cable usb connected to laptop...
    LPT set to ecp mode..
    the 4 resistors value=470 ohm or 100 ohm..
  2. #4307
    EUROPE
    the pin25 I have soldered to pin 4 of vcds but I have used 1kohm resistors and usb not connected to laptop I will learn someday
  3. #4308
    LPT to ECP?
  4. #4309
    EUROPE
    LPT to ECP?
    no I will test it must change and the resistors to 100ohm?
  5. #4310
    I found this BL/BM/RL dump, there is 11.11.5 and 12.12.0 installer, but I have tested only 11.11.5 and it's too big to upload here on forum.
  6. #4311
    12.12.0 longcoding not work
  7. #4312
    China VAG 14.10.2 PCB pictures attached
    Installation file looks to be the same as the one from RT website
  8. #4313
    It's on FTDI RL and NEC chip, not Atmega.
  9. #4314
    Quote Originally Posted by 1 6 D View Post
    is this a good thing or bad?
    it is working ok, can read measuring blocks and do long coding
  10. #4315
    NEC->cannot be updated by reprogramming.
    Haven't GAL/ATF chip, so, cannot made all K-line adaptations..
  11. #4316
    hi, i just install vcds 12.12.0, when i not plug it to car interface found ok, but when i plug to car "interface not found" can anyone help me? thx
  12. #4317
    What dump used?
    What 12.12.0 kit?
    What .ept?
    How is recognized in Device Manager?
    12.12.0 cn clone installers are for FA30 or FA24 PID.
    If use 12.12.0 for Fa30 with Fa24 the response is like yours..
    If dump is broken can be the same response..
    We cannot know what you have...
  13. #4318
    can yu please tell me what o check? i only instll sw and ty use cable first time ... thx
  14. #4319
    episcop's Avatar
    Portugal
    Hi, any body have tested! kit (hex,ept,soft) for 12.12, very more dumps from net, and i'm don't know what i have.....
  15. #4320
    @ yeager
    Explain more...
    What cable? From where you bought? If you bought from someone like 12.12.0, you must install sw and driver and must work.
    If not, contact seller.
    If you only download an 12.12.0 from internet and run with a cable you have, b.e. 11.11.0, never work, only if you make few opperations that are in this topic. Search with attn.
    @ episcop
    The same advice for "episcop" too, read this topic, all you need is here. And keep this: every sw is "marriaged" with a specific dump, ept. If use this "random" never work.
