Page 292 of 854 FirstFirst ... 192242282287288289290291292293294295296297302342392792 ... LastLast
Results 4,366 to 4,380 of 12803
  1. #4366
    EUROPE
    Quote Originally Posted by eliotroyano View Post
    I have cable error code G2KM=257. It will nice to now what means these error codes. About your cable, from my readings seems to me that your interface was detected and was deleted.
    so i must reprogram it or buy a new one?
  2. #4367
    Feb 2013
    If you will attach here some pictures with both sides of pcb, will see what hardware you have...and you will get more answers.
  3. #4368
    EUROPE
    Quote Originally Posted by alexm1 View Post
    I tried to erase the chip with avr programmer but always have power on failed can not find the chip.All connections are ok!I think I must order a new one.Anyone can suggest version and seller??Because I have already the 11.11.3 and it can not read the new pcr 2.1 can not find uds files.
  4. #4369
    @ kospoz: are you sure you have atmega162? If yes, must work. If is NEC D79Fxxxx cannot write.
    Like alex sed, post here few photos with both sides of PCB, is not a secret...
  5. #4370
    EUROPE
    no secret my friend i am waiting my new camera because my phone is very bad quality.Tomorrow i think I will have it
  6. #4371
    EUROPE
    Quote Originally Posted by kospoz View Post
    I have installed the vcds 11.11.3 with new cable that i bought it from china.The cable is working fine but in uds protocol on golf vi said that no asam data available and the errors was unknown.I had the 11.11.0 without this problem is something wrong with the cable?
    update if any friend have this problem with the label not found just try to connect with obd function and then the cable can find the lable with no problem.
  7. #4372
    Friends anyone have 704.1 english dumps? FT232BL+Atmega162?
  8. #4373
    Anyone have it?
    Other doubt. I have read many many times to take out STC chip from circuit. From the info I got from this amazing thread, I understand that STC is there for ATMega reflash (I suppose like an update when connected to computer by USB cable), then if I take out STC and repair my cable, should it not avoid to break again even using internet? I ask because supposely that way ATMega can not be reflashed/damaged again through USB port / computer, I ask?
  9. #4374
    DK Veteran KenshinPT's Avatar
    PT
    Anyone have it?
    I think the STC chip only repairs the FTDI.
    Sent from my LT30p using Tapatalk
    Did it help? Push Thanks below
  10. #4375
    Friends I think I found 704.1 dumps+sw, but how do you know if it is for FT232BL or FT232RL?
  11. #4376
    salkapone's Avatar
    Oct 2013
    Default vcds
    hello everyone .... I have these 4 devices ,,, someone who looked at the pictures , and to give me the proper dumps
  12. #4377
    Mar 2014
    Hello mates, I'd kindly need your help: I have got a china cable v.12.10 with software 12.10.3 beta. It worked fine for a couple of years (always on my netbook with WindowsXp pro sp3 with wifi off + Avira AV always disabled and pc-time always set to April 1st,2013). Unfortunately, recently I have probably forgotten for some minutes my wifi on and now I always get the here attached error: "not plugged into car" warning message.
    I also first noticed before this warning an odd behaviour during vcds connection to the car: initially it started giving me for more than a couple of time a "failure to communicate" error but after some attempts it started working fine receiving data from the car (ECU) but now I always have the "not plugged into car" message.
    I have also to tell you that this cable since the beginning never did a complete auto-scan of my car modules but it worked by checking the individual modules... I do not know if this was also regular ?!?
    Please also note that when I now connect the cable to my VW car the led turns on (green color) but if I only connect the cable to the netbook the led is off (no red or green color) though the cable appears as "Ross-Tech direct usb interface" with driver version 2.8.14.0 on device manager, is it normal?
    Moreover, if I give a look to the its hardware properties, I found out the following:USB\VID_0403&PID_FA24&REV_0600
    When vcds was working fine and I used to try the test button, I always got back a message similar to this one I found on the internet and here as attached picture, stating that everything was good. Now it isn't!
    Any highly appreciated suggestion to fix and restore my cable?
    Many thanks in advance.
    Cheers..
    PS: just FYI, I will also find here as attached images both sides of the PCB of my "china" cable.
  13. #4378
    Quote Originally Posted by mattydr67 View Post
    reprogramm it with good dumps.
    if you cannot change the ftdi VID/PID you have to change the 93C46 and the it will work.
    My freind liviudiaconu ( our mate ) just did this on an interface sent it by me.
    At this interface the VID_0000/PID_0000, I could changed it to VID_0403/PID_6001 and I did the procedure then tried to use VIDPIDFIX but had an error and with MProg I couldent reprogramm the FTDI.
    When I took off the interface from the USB and plugged back the VID/PID come back to the unknown device (VID_0000/PID_0000).
    The solution was:
    Changed the 93C46 and reprogrammed the Atmega like in the tutorial.
    This is it.
    Good luck
    Friends a question, only solution for VID_0000/PID_0000 is reprogramm 93C46 outside circuit????
  14. #4379
    u can use Mprog or Ftprog
  15. #4380
    Quote Originally Posted by ammarben View Post
    I have trying to revive my FT232BL cable without luck. Here are my results after trying UDFixer, VidPidFixer, Mprog and FTProg.
    MProg NoDevice.jpgUnknow Device.jpgUSB Device Driver.jpgVID_0000&PID_0000.jpg
    Some advice will be awesome.
