Hey all. I have an FT252BM chip, and have successfully loaded the VCDSFT232BL EPT to the cable using MProg. When I load up VCDS, it detects the cable and has no issues until I connect it to the car. From there, I hear the driver update noise from the computer, and i get issues, saying interface not found, etc. I do also understand that having a BM chip means I won't need a loader for VCDS - correct?
I believe this is due to needing to program the atmega, no? My computer doesn't have a parallel port, so i'm unsure of any other ways to manually program it (maybe build one with a SATA cable?). I get confused a bit because I know there is a difference between the RB/RM and RL. I assume the atmega needs to be programmed even though I do not have the RL interface.
Cable was originally an 812.4 and it still works with that version. Wondering if its possible to upgrade or if I should buy a new one.
Thank you for your assistance!
