Page 299 of 854 FirstFirst ... 199249289294295296297298299300301302303304309349399799 ... LastLast
Results 4,471 to 4,485 of 12803
  1. #4471
    RO-SJ
    @Overtune
    Please, can you share the soft that you get? Upload-it somewhere ... Thank`s!
  2. #4472
    Feb 2016
    I have the VCDS adapter as seen on the attached pictures on my workbench.
    The interface is connected to 12V (LED is green) and connected to USB (LED is red). In total orange .
    The problem is that VCDS always reports the "Status: Not plugged into Car".
    Until now I tried to resolder the Atmega and the other small parts like resistors and transistors and so on.
    Also the voltage regulator works fine.
    At the moment I have no Idea. I need some Help !
  3. #4473
    Dec 2012
    Quote Originally Posted by dorcky View Post
    @Overtune
    Will be no use to you
  4. #4474
    Quote Originally Posted by berndb View Post
    Intresting PCB. But the cable is, in fact, a China clone with "protect CI".
    In most cases, Green light with that message=interface was "erased".
  5. #4475
    Feb 2016
    I did't bought this. I am also sure that it is a clone from China. I did't see any PCB like my one in this Thread.
    Did you mean with "erased" that the software inside the Atmel was made unusable? Do I need to reflash the device?
    Which instruction can I follow to fix the device?
    Best regard,
    Bernd
  6. #4476
    Aminebot's tutorial for FT232R cables.
  7. #4477
    RF
    Give me please the English version vcds 15.6.1 Beta Installer.
  8. #4478
    Moderator
    PremierD's Avatar
    Jun 2009
    Sure mate .. if you want I'll get someone to hand deliver it .. along with a genuine Ross tech interface .. will that do ?????
  9. The Following User Says Thank You to PremierD For This Useful Post:
    Johnner (5th March, 2016)
  10. #4479
    RF
    Quote Originally Posted by PremierD View Post
    I change my post.
    PS
    Thanks, isn't necessary any more. Kind people have given me it.
  11. #4480
    Dec 2015
    Default vcds problem
    Hello folks.Here i publish pictures on my VCDS device.Bought it few years ago and accidentally updated it..As i know it is not original and firmware destroyed.I tried couple of dump files but the problem is "K1 : Short to ground".. Does somebody know how to fix it ? There is communication with parallel and usb port without issue..Please help me to fix it.. Thanks
    Chip is FT232BL
  12. #4481
    Mar 2016
    hi, all
    can anyone please PM how to find serials in dumps and vcds
    if it's not too ambitious for the first post
  13. #4482
    Mar 2016
    Hello, I can use this product for dump cable VCDS 15.7 with chip- ATMEGA162 + 16V8B + FT232RL?
    http://www.aliexpress.com/item/A11-F...e-1c4c821711ce
  14. #4483
    Feb 2013
    Yes, you can use that programmer (+ extreme burner) to reflash atmega.
  15. #4484
    Quote Originally Posted by hsnlpy View Post
    Chip is FT232BL
    Err. appeared before updating? If yes, U8 or U9. If not, U8 or U9 or something else (is not an "usualy clone").
    Quote Originally Posted by mfrpayp View Post
    hi, all
    I hope NONE of us will talk about this subject wiyh you....
    btw, is the ONLY ONE subject you are intrested?
  16. #4485
    Dec 2015
    Hello, i have original vcds interface, but its license is "revoked". Ross-tech suggested me to purchaise another cable with some discount) is there any way to make him work?
