Page 305 of 854 FirstFirst ... 205255295300301302303304305306307308309310315355405805 ... LastLast
Results 4,561 to 4,575 of 12803
  1. #4561
    Mar 2016
    sunderland
    hello mate can you help i got a 3t0035680 columbus when it powers up only stays on for a few seconds then of any idears thanks
  2. #4562
    hi
    i need login 11 engine code access... golf 2.0 2007 12233 not work
    any solution please??
  3. #4563
    Feb 2013
    Try this combinations:
    11463 or 01283 or 13861
  4. #4564
    smirnoff_rules's Avatar
    Mar 2008
    birmingham
    Can you tell us where can we found these vcds european clones..?
    Inviato dal mio HTC One utilizzando Tapatalk
    for the price of a genuine one they are worth it , not many original tools are as cheap , if you have a garage ?300 isnt a lot for an entry tool like this with free updates for ever
  5. The Following User Says Thank You to smirnoff_rules For This Useful Post:
    gazvts (29th July, 2016)
  6. #4565
    Sep 2008
    i had to get another laptop for garage and see vcds is installed but an older version 11 or 12 i think,next door has a higher think it was 15?. question is i want to get a usb lead to work are they all the same on fleabay as some state older versions and others latest.
  7. #4566
    Oct 2015
    my aplication VCDS not start the software.......in tasck manager It appears for 1 second vcds.exe and disappears....the software does not start
    My computer is new formatted
    not have install antivirus
    https://mega.nz/#!Z5cXjK4T!RCwJMz2rdP9NzErcosIp0Ryc3O7oLH-D-8U1gN4cAgU
  8. #4567
    May 2013
    Lithuania
    Hello all, have few questions about upgrading fw of my clone cable (please see attached photos).
    Now its running 1.84fw and 10.6.4 vcds version. I would like to upgrade to latest available fw 1.92. Just want confirmation from you guys that all steps are correct. By the way, for upgrading atmega I will use usbasp programmer. So the steps to update are:
    1. Connect usbasp to atmega like in attached photo. One more question, can i use 12v power from pc power supply?
    2. Have to flash atmega with eXtremeburner by using epprom - vers 6 11.11.5-12.12.0_eeprom 512 rl.hex, for flash - flash_192.hex, and for fuse bit seetings - security bits 320 bits.JPG
    3. Have to flash FTDI chip with MProg with VCDSFT232BL.ept
    4. Install VCDS-Release-12.12.0-Installer English 512bits.exe
    Did I miss something? Thank you
    All files attached
    https://ufile.io/56a07
    Edit:
    Just flashed my cable, all working as it should. FW 1.92 now, and 12.12 working, just did autoscan, no problems.
  9. #4568
    Feb 2013
    If you need longcoding you should use 11.11.5.
  10. #4569
    Sep 2016
    Hello, i am trying to dele EGR on a 2011 1,6 tdi passat. can i do this with my 12.12.0 china cable. It also says that i am missing rod file vw36
  11. #4570
    ghostrider72's Avatar
    Jul 2012
    UK
    Not doable with VCDS
  12. #4571
    Nov 2013
    Quote Originally Posted by easycome View Post
    I have the same clone and same problem, my cable is 15.7.0
    This Software versi?n is chinnese cracked, and dont start if cable not is Ok, I think Atmega162 is gone but Fw.1.94 not available yet, or yes?
  13. #4572
    Feb 2013
    If cable is not conected to the PC, vcds will run?
  14. #4573
    Nov 2013
    Quote Originally Posted by alexm1 View Post
    chinnese VCDS 15.7.0 not run without usb connected, nothing happen when run vcds.
  15. #4574
    Feb 2013
    I see several users with same problem in the same time, you can try to change date/time (ex. 01.07.2016 or earlyer+no internet) an see if it hepls to let it run.
  16. #4575
    15.7.0-STC, not ok as-is. Too many stc errors.
