If you made it how described in tutorial, it works very well. Erase->set Fuses->write flash....no problem there.
Hello guys,
I've a strange problem with china clone vagcom 10.6
The hardware of this clone is the same of tutorial 908 with FT232RL. When I plug the cable in usb port windows xp tell me about driver ! I try to select the VCDS forlder for driver, but it don't find it.
The interface is recognized like "Ross-Tech HEX-USB".
When I try to open the VCDS program, it tell me: "Cable not found Error Code=-1".
What is the problem ? I need to reflash some chip ?
Thanks![]()
Could someone programme atmega162 for vcds908 with all configurtaions and then to read it with ponyprog READ ALL. On this way we will get one configurated and working file. His size should be 16.6 KB. Thank you for the help!
Hello!
Know anybody anything abaut autokeydevices.com?
Did anybodi ordered from they?
Are they coorect, or no?
Thanks for answere!
You can do it yourself if you want this
set fuses to
EXT F9
HIGH DC
LOW CD
LOCK CC
It's right config uP for VCDS
You can check every bit with help from this page Engbedded AVR Fuse Calculator
Zibi
I think you're confused!
I am not quite sure about what are you trying to say... but if you want a dump with fuses, forget it. You need to program first the FLASH+EEPROM and then you set the fuses.
Why? Because when you read the dump (READ ALL) you just read the FLASH+EEPROM. The fuses aren't read.
You need to read and program fuses using "Configuration and Security Bits" (on PonyProg).
I'm right?
Im new here and got a problem. I read the whole thread but didnt find a solution or then I just didnt understand. I have a chinese vag com can bus usb ver: 805.1. The connection with the car works fine but whenevery I try to make autoscan it stops in the same certain point and says that you need to register. Even tho it says that its fully registered. When I try to make long coding it says the same thing. Yesterday I got it working for a while that it didnt say about register in long coding but the changes didnt stay.
Thanks for help and sorry if this has been answered before in this thread.
You need to reflash your cable with good dumps![]()
How to update Vcds hex-can to last verison????
Need dump for update and how????
Somebody know???
1. Buy original (automatically updates to latest versions)
2. Get latest dumps and reflash atmega (Read whole thread and you'll found how to do that)
3. Give to somebody who have files and know how to do that
