Page 313 of 854 FirstFirst ... 213263303308309310311312313314315316317318323363413813 ... LastLast
Results 4,681 to 4,695 of 12803
  1. #4681
    Nov 2015
    Quote Originally Posted by kolimer View Post
    I want to publish new cracked VCDS version 17.1.3. Inside the archive there is HWType detect tool, ATMega dump (FW+BootLoader for HW type 0x44 & 0x46 + EEPROM), FTDI EPT and XML file, original installer and cracked exe. Cracked exe disables internet connection to ROSS, marriage with FTDI Chip ID and clears blacklisted serials.
    Tested on my car and it is working.
    The archive can be downloaded from http://www.mediafire.com/file/tl25s9...CDS_17.1.3.zip
    Hey ,
    I have this here :
    The HWType detect tool output :
    FIRMWARE : 1.93
    HARDWARE : 0x46
    Indifikation : Hex-OEM
    How can i update it to new firmware ?
    Thank you .
    Gesendet mit Tapatalk
  2. #4682
    Feb 2013
    You have there : CHINA= NEC thats equal with no update=no reflash.
  3. #4683
    Nov 2015
    Really not ? There is firmware for china clone :
    http://www.digital-kaos.co.uk/forums....php?p=2924942
  4. #4684
    Nov 2015
    And this one :
  5. #4685
    Feb 2013
    This looks ok, but see my edit pic and see if you ca read in the red area..? Should be Atmega there..if so , you can get to work and reflash.
  6. #4686
    Nov 2015
    Yes is it
    Atmel
    Atmega 162
    16AU 1639H
  7. #4687
    Yes, but on yours write: D79F..., NOT Atmega162.
    Anoter chip, another FW, not compatible
    Your cable is badbadbad.....bad china clone.
  8. #4688
    Nov 2015
    Ok so the first vcds is very bad china copy.
    The second with Atmel is ok? The latest firmware. If it comes new I can update? how exactly ? With usbasp ?
  9. #4689
    Feb 2017
    Quote Originally Posted by FoxMulder View Post
    China clone firmware is the same as FW for HW 0x46 except boot loader. There is not public firmware for NEC CPU.
  10. #4690
    Feb 2017
    Buy an interface with ATMega and ideally with programming header.
    http://www.obd2cartool.com/vagcom-16...version-p-1266 is the good one. AES protection chip is only for someone who wants to protect his crack or loader to be used only with his interface. STC chip does the some - protects the crack/loader, it does NOT protect ATMega EEPROM memory.
  11. The Following User Says Thank You to kolimer For This Useful Post:
    ireun (29th March, 2017)
  12. #4691
    Nov 2015
    Yes that is one :
    http://www.digital-kaos.co.uk/forums....php?p=2986116
    How to program it ? Is there a guide ?
  13. #4692
    Feb 2017
    How can I program the FTDI-Eprom with the BIN file
  14. #4693
    Feb 2017
    Yes that is one :
    Programming is simple through programming header and usbasp interface http://www.ebay.com/itm/USBASP-USBIS...8AAOSwuzRXdhtk
  15. #4694
    Nov 2015
    OK . How is the connector laid ? To connect it?
    Look picture:
  16. #4695
    Oct 2016
    The vcds_17.1.3_cracked.exe may not be perfect
    Although can change this instructions
    00495D5B CMP EAX,00000020------->CMP EAX,0000000
    But VCDS will check the integrity of the code
    00495D8B PUSH 00000020
    00495D8D POP ECX
    00495D8E CMP DWORD PTR [ESP+20],ECX
    00495D92 MOV AL,BYTE PTR [ESI]
    00495D94 JGE 00495DA6
  17. The Following 3 Users Say Thank You to 34260551 For This Useful Post:
    alexm1 (21st March, 2017), kolimer (21st March, 2017), tr3ce13 (4th June, 2017)
