Page 317 of 854 FirstFirst ... 217267307312313314315316317318319320321322327367417817 ... LastLast
Results 4,741 to 4,755 of 12803
  1. #4741
    Oct 2016
    hello makadam,if you can continue to replace FT232RL from working cable,It may work. sometimes, the data of FT232RL is important for clone cable also.
  2. #4742
    Aug 2010
    Quote Originally Posted by zagaaa View Post
    Hi guys
    I have 17.1.3 here but it has rod file errors and communication. Any way I can flash it or use new crack software so it works better?
    Attachment 439584Attachment 439585
    and help with this cable friends?
  3. #4743
    Dec 2016
    Vilnius, Lithuania
    I have reverse engineered old 10.6 cable (because it blinks red when GAL installed with kolimer`s dumps, works fine with gal delete tho) in case someone needs it for some purpose. Will reverse engineer 12.12 cable tomorrow as well.
  4. The Following 6 Users Say Thank You to Elektrik1 For This Useful Post:
    andrei88 (2nd April, 2017), Domi (2nd April, 2017), ivaylomezdra (2nd April, 2017), morfej (24th April, 2017), paro44 (5th April, 2017), tr3ce13 (21st November, 2017)
  5. #4744
    @Electrik1: Is a very old "solution" for eliminate GAL. About 3-4 years ago. Chineses used idea for bad-cheap cables without GAL.
    Not recomended.
    @Zagaaa: Solution is another cable with Atmega162, with good dump and good cracked programm
  6. #4745
    Mar 2017
    I had read the whole topic, and i saw many good posts! Thanks!
    I still have a problem with my own cable. It's a X044 but i dont know which controller it is And it's protected against writing.
    It works like a charm with 12.2 but i want to upgrade it.
    I successfully changed the Serial of the cable so Vcds 17 does recognize it but it says it needs a firmware update. (it's 1.92 and needs an upgrade to 1.96) photo_2017-04-03_17-11-10.jpgphoto_2017-04-03_17-11-12.jpg
  7. #4746
    Feb 2017
    Quote Originally Posted by moxegy View Post
    Can't be updated. China NEC CPU with custom firmware (1.92). Only cables with ATMega162 CPU can be updated.
  8. #4747
    Dec 2016
    Vilnius, Lithuania
    Ok, I sorted out thing with GAL, connected pins like HW 0x44 and it worked with GAL (no need to gal delete).
    GAL/ATF programmed with TL866 programmer, GAL .jed file included in zip.
    Zip also contains .pdf of reverse engineered 12.12 schematic + .eps vectorial file if high res is needed.
    Works like a charm with Kolimer`s v2 dump (0x44) and his cracked .exe
  9. The Following 3 Users Say Thank You to Elektrik1 For This Useful Post:
    C3H8 (21st December, 2018), paro44 (5th April, 2017), tr3ce13 (21st November, 2017)
  10. #4748
    Feb 2017
    Spain
    Hi, I have an VCDS clone 12.12 (atmega162 and FT232RL) with problems and i want to repair it. This doesn't have GAL. I have any questions about the steps that i will follow, please correct me :
    1) Flash the FTDI with MProg using ept.
    2) Connect my AVR Programmer to the Atmega pins (see in the picture) MISO, MOSI, SCK and RESET.
    And the "Ground" on the pin 28 of the Atmega.
    For the power it's enought to supply only +5V to the pin 18 (VDD) of the MCP2512 ?? Or need i to put +12V on the 7805 regulator??
    3) Flash the eeprom and set the fuse bits CD/DC/F9/CC or FF
    Is that correct for my interface?
    I'm very grateful with the good job of this forum and I learn a lot of.
  11. #4749
    Aug 2010
    Not recomended.
    thanks for your message. what if i told you I have about 20 of these cables and cannot throw them away. Is it possible to use older version like 17.1 and this cable will work with it?
  12. #4750
    Quote Originally Posted by andrei88 View Post
    [...] This doesn't have GAL.[...]
    Without GAL seems to mean too "pins 34,35 Atmega unconected"->46->DA.
    You can use the version arrived with cables.
  13. #4751
    Aug 2010
    doesn't work well, get rod file errors.
  14. #4752
    You mean DA setting give errors?
    Or yours cable with arrived soft give errors?
    Next time whet "reply with quota"..delete expresion not need in response.
    Leave only needed quota part.
  15. #4753
    Aug 2010
    ok got it. The software with the cables gives .rod file missing errors for all these vehicles:
    all Golf 6, Polo 1.2
    Seat Ibiza
    SKDA Octavia
    VWPolo 2015
    VW Caddy 2011
    Passat B8 from 07.2014
    SKDA Fabia (5J)
    VW GOLF 6 1.6 TDI
    SKDA Octavia II 1.2TSI (engine CBZB) 2011
    VW Polo 6R 2012(OK)
    AUDI A6 C7 2014, 2.8 FSI
    Passat B8 MQB 07.2014.
    Passat B7 OK
    SKDA Rapid 2013
    VW Polo 1.2 TSI 2011
    VW Touran 2010 Silnik 1.6tdi CR CAYC
  16. #4754
    Junior Member Adyp's Avatar
    Mar 2017
    Hello all!
    I have read almost all 300 pages on this thread, very useful, thank you all for sharing info.
    Almost a week ago I have bought a clone, seller delivered a CD with official 17.1.2, on description said that official software will work. At least that i could read on that CD, it was a bit damaged. After autoscan license gone, Unregistered appeared. No internet, no update, just software from CD. I have contacted seller, no answer until now.
    Meanwhile, I have found some software, recovery.exe, and worked but when I am scanning I get some communication errors.
    Can I make it to work as it should?
    Pictures attached with inside!
  17. #4755
    What VID and PID appear in device manager?
    0403 and 6001?
    Is a little strange solution.
