I have VCDS 10.6 with ATMEGA162 and FT23BL onborad. However descriptions are telling about HW with FT232RL only. Will it work with FT232BL?
andrei88 (15th April, 2017)
Yes,working with FT232RL,in arhive dump for 93c46(eepromftdi.bin)
Info for all "VCDS" newbies:
VCDS with FT BL or FT BM chips can work with original VCDS software (no moded) IF you have good dumps (for ATMEGA and FT).
VCDS with FT RL is chinese "low cost" versions and only can work with VCDS moded softwares (cracked or have "loader"), and
always some of VCDS functions no work good.
So, the difference is obvious between the two TYPE devices
It's half true.
TRUE) For HW interfaces with BL or BM you can set any FTDI Chip ID, but it's extremely hard to find the dump and if used with internet connection, it's blocked in next version because ROSS will detect serial number used in two HW's.
FALSE) FTDI is only converter from USB to RS232 so HW with FTDI 232RL will work with good loader/crack and has no limitation compared to HW with BL/BM
I can't flash my vcds 157
I have the usbavr programmer. I followed the tutorial and done all connections.tried to read the atmega 162 with programmer+ extreme burner but got error 'cannot power up programmer'.
Can someone please help me with my cable.I never used this programmer..IMAG0548.jpg
Inviato dal mio HTC One utilizzando Tapatalk
Some more pics.
Led on vcds is flashing and led on programmer is on..
Did you connect also +5V? The LED must blink or lit green or led before flashing.
comizelu (17th April, 2017)
https://mega.nz/#F!iYMG0IoS!WqG9djt6aFLuU0lzSAgRIA use this link and see images pleaseI hope to help you
Finally I succeed read now.I plugged in the usb.and checked all connections
But now don't know what dump to use..x44 or x46
for my cable i use x44 when shared @kolimer and work perfectcheck this please https://mega.nz/#!zA9w2CoY!VbdR2WxdP...PpA6kvrs8VN7W8
Can someone give me advice on what dumps to use for my cable pls..
Thank you
just read info.pdf when i send you in previous my post
Thank you ivay..
Cannot write in 'fuse bits/settingsc'- calibration..
To me is ffffff62 and cannot change to ffffff5e.
I use Extreme burner.is it gonna work the same or must change.
Thank you
