just make this please , download AVR when i give you in link, down in my post and use images
https://mega.nz/#!uQlj2K5D!pDRj_E1Ij...oNuQJSvxQuMCSQ
comizelu (17th April, 2017)
Works great
Thank you ivay
Inviato dal mio HTC One utilizzando Tapatalk
Updated to 17.1.3
Didn't check adaptations, but looks like everything is working OK.
Version 0x46 with FT232RL.
Thanks!
If someone in PL has problems with it, I can help.
Use ftdi_mprog.ept and reflash atmega.
comizelu (22nd April, 2017)
see attach for FT232R. After this search good dump Atmega+installer.
Can you help
I can not activate TPMS with vag com 2013 Caddy
abs byte 16 bit 2 error
no active
ABS Frenler (J104) Etiketler: 1K0-907-379-60EC1F.clb Adres 03
Par?a No GB: 1K0 907 379 BL HW: 1K0 907 379 BL
Bileşen: ESP MK60EC1 H31 0152
Revizyon: 00H31001
Kodlama: 423C400D09230301420B02E69019C041310000
Mağaza no: WSC 35110 377 00141
VCID: 7DF19392E43044AACB-8028
I'm getting the error below
http://www.directupload.net/file/d/4...p7bcjd_png.htm
Error 31: Request out of range - Coding Rejected.
It means that module doesn't support this function.
Guys. I need a VCDS cable with Atmega, but on aliexpress there are i think only cables with NEC chips, do you have any link with Atmega chip?
Thanks.![]()
Could be Nec or Atmega? I never saw this type of cable until now.
Seller says that is working with vcds 10.6 .
http://www.obd2cartool.com/vagcom-16...version-p-1266
http://www.obdkcan.com/vagcom-1684-f...196_p1281.html
It's with programming header
Hello dk team i am looking for good sw 16.8.4 without virus
hi Guys.
I have buyed this china clone.
Vagcom 17.1 full active vcds 17.1 China crack VAG 17.1 For VW Audi Seat Skoda ,V17.1 VAG Diagnose Cable support all systems diagnostics including K1,K2,CAN,UDS. full active vcds 17.1 with ATMEGA162 + FT232RL + L9637D + 16V8B.
http://www.obd2cartool.com/vagcom-17...t-skoda-p-1341
Can i update it to kolimer crack ?
The hardware detection tool say no interface found!
You need to connect it to the car first or supply +12V
EpicFail78 (24th April, 2017)
