Page 323 of 854 FirstFirst ... 223273313318319320321322323324325326327328333373423823 ... LastLast
Results 4,831 to 4,845 of 12803
  1. #4831
    Quote Originally Posted by alexm1 View Post
    Your problem might be the FTDI -RQ on your PCB, as I read on earlyer pages, kolimer's dump are for FTDI RL type.
    The same thing, as kolimer already said.
    Quote Originally Posted by gumacz100 View Post
    Hi. I write 17.1.3 kolimer 0x46 https://goo.gl/photos/7S6NMTUNLojr9YRp9 My pcb https://goo.gl/photos/HogpGRSVaqYkhDoZA and I'm have problems with this https://goo.gl/photos/AoTpjgJCa6JCJwRy8 I'm don't see fault codes, dynamic logs works excellent in kline and CAN cars.
    Are you sure you have DTC on engine? Or is only a generic example and for all controllers display the same message? Btw, your HW is a very good HW, one of the goodest HW i saw. Almost a exactly clone of OEM cable. The 7805 is maximum warm, never hot.
  2. #4832
    Feb 2017
    Quote Originally Posted by angelx431 View Post
    Not FT232RQ and FT232RL. My VCDS FT232BM. Search only BL, BM
    So no "Search EPT file FT232BL for version 17.1.3" as answer to previous post, but "I'm searching EPT file FT232BL for version 17.1.3" as request !
  3. The Following 3 Users Say Thank You to kolimer For This Useful Post:
    angelx431 (25th April, 2017), ireun (25th April, 2017), ScratAudi (9th May, 2017)
  4. #4833
    Hi please dumps for vcds 17.x.x ?
  5. #4834
    Feb 2013
    please read a little more ( previous pages) .
  6. #4835
    Feb 2017
    Quote Originally Posted by skroman View Post
    Search more.
  8. #4837
    Mar 2017
    Quote Originally Posted by EpicFail78 View Post
    hi Guys.
    I have buyed this china clone.
    Vagcom 17.1 full active vcds 17.1 China crack VAG 17.1 For VW Audi Seat Skoda ,V17.1 VAG Diagnose Cable support all systems diagnostics including K1,K2,CAN,UDS. full active vcds 17.1 with ATMEGA162 + FT232RL + L9637D + 16V8B.
    http://www.obd2cartool.com/vagcom-17...t-skoda-p-1341
    Can i update it to kolimer crack ?
    The hardware detection tool say no interface found!
    hi guys
  9. #4838
    Quote Originally Posted by kolimer View Post
    I want to publish new cracked VCDS version 17.1.3. Inside the archive there is HWType detect tool, ATMega dump (FW+BootLoader for HW type 0x44 & 0x46 + EEPROM), FTDI EPT and XML file, original installer and cracked exe. Cracked exe disables internet connection to ROSS, marriage with FTDI Chip ID and clears blacklisted serials.
    Tested on my car and it is working.
    The archive can be downloaded from http://www.mediafire.com/file/tl25s9...CDS_17.1.3.zip
    Please link not work
  10. #4839
    Feb 2013
    @EpicFail78
    Chose dump for hwx46 from kolimer rar(zip).
    Can you share vagcom_hwtype detection tool?
  11. #4840
    please link
  12. #4841
    Nov 2016
    "Are you sure you have DTC on engine? Or is only a generic example and for all controllers display the same message? Btw, your HW is a very good HW, one of the goodest HW i saw. Almost a exactly clone of OEM cable. The 7805 is maximum warm, never hot."
    This is clone cable vcds 16.8.3. All controllers have problem with this.
  13. #4842
    Feb 2013
    please link
    thys is the link shared by kolimer
    try if it still works
    https://mega.nz/#!oyowxRDY!1vVTUiAJD...ABkmS-Qtlrjupo
  14. #4843
    Thank you already i have
  15. #4844
    Feb 2013
    I found hw type detection tool, was in kolimer .rar - my mistake.
    About using this tool: I just have to conect usb(vcds) to PC and hit READ?
    I tried that for 2 cables and : Interface not found!
    Trimis de pe al meu SM-N9005 folosind Tapatalk
  16. #4845
    Mar 2017
    @alexm1 you need 12v plug in your car or use USBASP+ plugin the interface on laptop!
    @ free download HWType detect tool, ATMega dump (FW+BootLoader for HW type 0x44 & 0x46 + EEPROM), FTDI EPT and XML file, original installer and cracked exe http://www99.zippyshare.com/v/n4D48ct1/file.html
