Page 326 of 854 FirstFirst ... 226276316321322323324325326327328329330331336376426826 ... LastLast
Results 4,876 to 4,890 of 12803
  1. #4876
    Feb 2013
    I do not want to deny kolymer.s work, I believe that should work good, as you say, I just can not figured out what I doing wrong.
    - hw46
    - for fuses -see picture
  2. #4877
    Apr 2017
    hello i have this old cable 12.12
    will it work?
    FW Version : 1.92
    HW Version : 0x44
    Identification : ROSS-USA
  3. #4878
    Feb 2013
    What is written on the marked area?
    China?
  4. #4879
    Apr 2017
    D79F8513A
    1436XB059
    CHINA
    ON THE BACK
    MCP2561E
    MCP2515
  5. #4880
    Never work updated with "Atmega's methods"..
    D79F...=NEC, NOT Atmel.
  6. #4881
    Feb 2016
    Moldova
    Quote Originally Posted by alexm1 View Post
    - hw46
    1) I have write FF for lock fuses.
    2) About calibration - I saw that people also write something here. I dont know because I use Xprog for update, and Xprog don not have this calibration window of course!
  7. #4882
    Feb 2013
    For calibration I use FF...
    I will try again with FF for lock fuses.
  8. #4883
    Nov 2015
    Foto fuse bit to pony prog 0x44 - 0x46 please
  9. #4884
    May 2017
    Hi all,
    Please help me with some information's, please:
    I have VCDS interface from attached pictures, during of SCAN process was displayed one error message: This function required licensed interface. I mention here never update the software and WI-Fi closed, I used only version 15.7.3.
    I installed fresh copy of the software (15.7.3) but with the same error message.
    My question is if the error message indicate one damaged interface and must be repaired?
    If yes can you guide me how?
    Thank you for your help.
  10. #4885
    Feb 2016
    Moldova
    Quote Originally Posted by real898 View Post
    Use online fuse calculators for this
  11. #4886
    Feb 2016
    Moldova
    Quote Originally Posted by mpcb View Post
    Hi all,
    By flashing Atmega you can solve this problem. Show screen from @about@ window!
  12. #4887
    May 2017
    Unfortunately I don't have fw for 15.7.3 sw, which version of fw I can put on the interface?
    Or where I can found the fw for 15.7.3?
    Thank you.
  13. #4888
    Feb 2016
    Moldova
    Thank you.
    If you have Atmega on board (on foto for sure is Atmega162), then read this thread. You find here all information that you need.
  14. #4889
    Oct 2016
  15. #4890
    Nov 2015
    thanks 34260551
