Page 32 of 854 FirstFirst ... 2227282930313233343536374282132532 ... LastLast
Results 466 to 480 of 12803
  1. #466
    Junior Member Carlos_'s Avatar
    PT
    What is necessary? I have been reading thread to understand and i think i have, but if you could explain me, i would apreciate. By the way, if the cable is deprogrammed via usb, why can't be programmed in the same way?
  2. #467
    DK Veteran KenshinPT's Avatar
    PT
    Quote Originally Posted by dlhy View Post
    Hi, when i use dump and software in this archive it still blocks my cable untill i use crack on software from aminebot.Then it works.Can u tell me wheres the problem?
    Maybe your cable is the crappy china version that uses the FT232RL. If it's the case my package won't help you. You need to use animebot solution.
    Sorry
    Did it help? Push Thanks below
  3. #468
    PT
    Quote Originally Posted by Carlos_ View Post
    Hi, can anyone tell me if it is possibly to program ANY vag-com cable to the latest version?
    Sorry for my english
    Any VAG-COM / VCDS cable that uses an ATMEGA can be upgraded. If it's based in the FT232BL use my package above (post 453). If it's based in the FT232RL I'm not the right person to help you, yet.
    I do not own any file. I just made a compilation of files that will help you out.
    The package includes a help file made by animebot.
    Good luck
  4. #469
    PT
    The ATMEGAS's FLASH can be reflashed via USB. However the ATMEGA's EEPROM... I don't know if it can be reflashed via USB.
    Believe me, for now forget the USB reflashing. Build your own LPT programmer or buy an USB programmer. Then play with your programmer and VCDS cable.
    Later I can explain you the USB reflashing But you will need a programmer no matter what.
    Good luck
  5. #470
    Portugal
    HELLO. First I want to say that this forum is the best. I have a problem with the developer to build. I have used the scheme of the Lancos, and it worked fine until yesterday. Now the flash and then sends me the error -21 and cable neck longer works, I use pony program and does not recognize the ATmega 162. right now I have two cables damaged. can anyone help me please.
    Thank you.
    Sorry for my bad English.
  6. #471
    xoom's Avatar
    Ylakiai
    Hi, first you have to findout what is faulty.. Your programmer or your atmega.. maybe you set wrong fuses (clock fuses) and now you atmega doesn't start.. in this case you have supply clock for it... but if you can't program brand new atmega then your programmer is faulty..
  7. #472
    Aug 2010
    Czech Republic
    finally I have made working hex-can cable with 805 dump from angelx431. Thanks to all for help. But I have another question, please, can anybody tell me, where can I find the crack for vcds 805 or 908. I suppose, that the serial number is saved in atmega, but i need to generate activation code.
    Or I can use dump from KenshinPT, but the problem is the same. I have only unlicensed version of vcds. Thanks
  8. #473
    xoom's Avatar
    Ylakiai
    if you had good dumps(eeprom) and not cracked soft it should automatically show as fully registered/actived..
  9. #474
    Portugal
    Quote Originally Posted by xoom View Post
    Thanks. But how do I can supply the clock, in lancos programmer?
  10. #475
    Oct 2010
    Hi everyone,
    The product vag 10.6 china clone arrived in the morning. It looks good, but i have a problem with software instalation from the CD i received. During the installation process vcds software 10.6 <and others in the CD> an error with vsds.exe file has appeared, and i could only press "ingore" to continue the installation. after that vcds.exe hasn't created and the program didn't start.
    Is it possible to download the newest software form http://www.ross-tech.com in version 10.6.3 and install, because with this version installation process is complete and vcds.exe starts normally without interface, or i will damage it??
    Do you have any experience with that??
  11. #476
    xoom's Avatar
    Ylakiai
    Quote Originally Posted by toquim View Post
    You have to make separate device (square wave generator) about 1MHz clock and supply it to XTAL1 pin. You can make that generator with NE555 timer chip.. or with other atmega
    for example i wrote code for ATMega8 and its generating about 1MHz clock on 2 PIN (PD0)
    in attached file is hex file for atmega8 (no need to change fuses, factory fuses is ok)
  12. #477
    xoom's Avatar
    Ylakiai
    Quote Originally Posted by neopfk View Post
    Hi everyone,
    I don't believe that helps you.. Ask your seller to send you soft.. these cables working with cracked soft..
  13. #478
    Oct 2008
    On Earth
    Hi everyone,
    Uninstall your AV first and then including the VCDS folder in the exception of your AV.
    For couple weeks all AV's erase this VCDS 10.6.0 cracked version.
    So do this and try to install again.
    Good luck
  14. #479
    Dec 2010
    mattydr67 :can you contact me thanks
  15. #480
    Oct 2010
    Quote Originally Posted by mattydr67 View Post
    Good luck
    What do you mean "AV"??
    Thaks for reply
