Page 331 of 854 FirstFirst ... 231281321326327328329330331332333334335336341381431831 ... LastLast
Results 4,951 to 4,965 of 12803
  1. #4951
    Jan 2017
    Quote Originally Posted by 34260551 View Post
    a german dump marriage with your FTDI Chip ID and a cracked german version
    Please don't mind that I ask, but where did you get the dump from? You did it by yourself?
  2. #4952
    Oct 2008
    I'm just ding this myself. this is my boards pin out which has the same header as yours.
    pin 1 of atmega = pin 1 of header (as I'm assuming pin 1 is the first pin nearest the usb connection cables on the PCB)
    pin 2 " " = pin 2 " "
    pin 3 " " = pin 3 " "
    pin 4 " " = pin 4 " "
    pin 5 = GND
    pin 6 = VCC (+5V) the last pin of the header and nearest the Car connection.
    I have found my usbasp GND seems to be the other end of the VCC on the ribbon connector. as when I used the pin next to vcc I couldn't get any coms.
  3. #4953
    Home
    Does anyone have decoding skill for codes.dat ?
  4. #4954
    Oct 2016
    Quote Originally Posted by ni88l3r View Post
    A original serials for 16.8.3 only:
    :10000000FF4845582D4F454D200000015F94816CFD
    :100010001D0424FFFFABFFFFFFFFFF020E000000E7
    :1000200000447000FFFFFFFFFFFFFFFFFFFFFFFF28
    :10004000DC545F4E8B21D98DE08217985AD2511C17
    :10005000E2D18D98657E02CF8803A510FAE4A797B8
    :10006000AC485A3DB69B2AF0A2FE35E651CBC0877C
    :100070004033AF3978113180EF7B4A8CE36E64F501
    :1000800024BB5724035F644FC9FE7A4727F589775D
    :10009000ADF169F45B2C9734014A57B1A4815C9AA5
    :1000A000AB75F6A0D4F852AFC183B91FC53C81002F
    :1000B00073860000015F94816C1D1FFF0000A1D0BA
    :10010000AA5570917E6333B1FFFFFFFFFFFFFFFF32
    :10011000FFFFFFFFFFFFFFFFFFFFFFFF2FBFA4F366
    :10012000323031362F30362F323720313068303888
    :100130003A343920303020303300000000008D3454
    :00000001FF
    for 17.1.3 create a fake sn
  5. #4955
    Jan 2016
    hi guys
    i have finally flashed my device,
    tested on golf 7
    Now with some errors, maybe somebody can help here:
    1. At Scan i get lots of "COMMUNICATION ERROR" popup, is this fixedable?, but the ECU are found
    2. try to use KOMBI LongCoding, after change the value, press "DO IT!" nothing change, i get old value back
    is there a fix for it?
    HW 0x46, WIN7 x64
  6. #4956
    Feb 2017
    Great news. VCDS 17.1.3 German version
    http://ge.tt/4j31aHk2
  7. The Following 12 Users Say Thank You to kolimer For This Useful Post:
    34260551 (29th May, 2017), abdulsattar (26th July, 2017), bibkare (8th June, 2017), Domi (30th May, 2017), EpicFail78 (29th May, 2017), hoho1 (29th May, 2017), miouser (30th April, 2018), Moldovan1 (29th May, 2017), ni88l3r (29th May, 2017), paro44 (30th May, 2017), uragan1987 (29th May, 2017), vaicekas (31st May, 2017)
  8. #4957
    May 2017
    You have also version English ?
    And please users type me how i can update my cabel VCDS 11.11.5 to 17.1.3 ?
    How i can identify my cable is 0x44 or is 0x46 ?
    This is my:
    https://goo.gl/photos/Lnb21G1m4pZvpCXu5
  9. #4958
    Feb 2017
    Quote Originally Posted by pepeEL View Post
    This is my:
    Read the forum !
    http://www.digital-kaos.co.uk/forums...YTHING/page314
    http://www.digital-kaos.co.uk/forums...=1#post3015408
  10. The Following User Says Thank You to kolimer For This Useful Post:
  11. #4959
    May 2017
    Ok but you can give me full manual how change version my cabel ? How change firmware and other ? Please
  12. #4960
    Mar 2017
    Quote Originally Posted by kolimer View Post
    Thanks Kolimer.
    I have Download and flash all files. But no cracked exe in the archiv.
  13. #4961
    Feb 2017
    Inside the archive
  14. #4962
    Mar 2017
    Hi kolimer thanks works fine .
    Great Job dude )
    My Eset was deleting on my temp folder your cracked.exe on Setup installing!
    Solved and sorry!
  15. #4963
    May 2017
    Quote Originally Posted by EpicFail78 View Post
    Great Job dude )
    Solved and sorry!
    Can you write me step by step how you do it ? And what programmator you use ? Thanks.
    And on this FW we can use internet and we can enable internet ?
  16. #4964
    Jan 2016
    kolimer thx alot
    LONG CODE works???
    PS: WIN10 Defender , Trojan: Win32/Fuery.B!cl
  17. #4965
    Mar 2017
    @uragan 1987yes long code w?rks.
    dissabel antivirus install it and exclude it from ANTIVIRUS Software!
    pepeEl
    http://www.digital-kaos.co.uk/forums...YTHING/page309
    You need USBASPv2.0 Programmer from ebay.
    Programm that i used .
    Mprog3.5 for flash the EPT file and Extrem burner for Flash Firmware and EEprom Serial+ Fuses!
    My interface! 0x46_ hardware!
    My USBASPv2.0 Programmer from ebay!
    0x46_fuses
