open Mprog and load the EPT File from Kolimer Gift )
Then use scan and programm.
Use the Hardware detection tool from kolimer.
You need plugin the interface cabel and your usbasp programmer on your laptop to make it work for detection the Hardware.
USBASP TO VCDS ATMEGA.pdf
ok but i have this hardware
https://goo.gl/photos/Lnb21G1m4pZvpCXu5
I dont have pinout to programm. I must solder remove ATMEGA to program ?
I can guarantee that it's virus free. https://www.virustotal.com/cs/file/b...is/1496087743/
Domi (30th May, 2017), EpicFail78 (30th May, 2017), paro44 (30th May, 2017)
Thanks Kolimer! You made a great job! I`m so waiting this moment! You English version work very good, tested on many-many cars (both Kline and CAN, both short coding and long coding, from 1998 MY to 2015 MY). And now - I go to flash my HW with german dump. Many thanks again!
PS No need to flash Atmega! Atmegas dumps for both version is the same! Even ftdi dump is the same. Very good news.
ni88l3r (30th May, 2017)
Ok but not remove from PCB ? Only wire solder to chip on PCB ?
User sdfxcv reshared http://www.digital-kaos.co.uk/forums...=1#post3015408
AntiVirus Problems only at WIN10, but thats not the problem.
I have installed on my Notebook, Win7x64, the ENG or GER Software works fine.
THe Problem is Nr.1 , "Communication error", like this: http://imageshack.com/i/pmVS5evqp , this image i foundon google
You have this too?
Problem Nr.2 is: Long Coding
I can read the data of Long Coding. after Press "DO IT!", i get the MessageBox "Coding Accepted" but nothing changed
Maybe possible to fix it? its same as on 12.12.0
EpicFail78 you checked the long coding?
I do not know the reason why for someone it works well and why some has problems with "Communication error".
I have only this interface http://www.obd2cartool.com/vagcom-16...version-p-1266.
The cause may be a bad china clone.
I use Windows 7 64Bit on my laptop and all works fine. German and English version .
For me no problem with my hardware!
ATMEGA162 + FT232RL + L9637D + 16V8B
http://www.obd2cartool.com/vagcom-17...t-skoda-p-1341
Many thanks @kolimer for the great work!
Tested on 16.8.4 hw.46 broken interface, which is now resurrected to latest version !
i have 11.11.3 china clone flashed to 17.1.3
maybe my hardware is too old for this
